Stalling when wet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scottnj, Jun 18, 2003.
  1. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    I need some help. Took the blazer out last weekend.
    Hit some water and it stalled and would not start for about 10 minutes. Distributor got wet. Never had this problem before. Could the coil be shorting out until it dries, would that do the same thing?
  2. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I'd check for some cracks in your distributor cap. I had one that ran just fine but let water seep in and the motor would die. Maybe this helps or maybe clues someone else into the right path. Good luck.
    Allan
  3. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Yeah, cracked cap or damaged coil housing or wiring is what I would look at
  4. scottnj
    Aug 4, 2001
    112
    Central Florida
    Thanks for the help. It is a new cap and rotor and new wires but I have never replaced the coil.
    do you think it is worth going to one of the higher end ignition companies for a new cap, rotor, and coil?
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Try sealing what you have.
    And try and go slower with the water.
    You were lucky it was just the distributor.
    Mine injested water through a loose air cleaner housing.
    Took me an hour to remove spark plugs, pump water out through hole, clean spark plugs and install.
    plus drying up the dist. and then it fired right up.
    /forums/images/graemlins/thumb.gif
  6. scottnj
    Aug 4, 2001
    112
    Central Florida
    Actually was not lucky at all. I sucked lots of water right after that happened. Lots of water went through the tailpipe....well actually I guess I am lucky it is running just fine now. water logged
  7. scottnj
    Aug 4, 2001
    112
    Central Florida
    Whats better msd or accel coils? or are they about the same?
