stalling
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by new2k5, Mar 29, 2003.
  1. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    i am haveing trouble with my 87 k5 it will be ok for a couple miles 25 or so then it will start stalling whenever i'm not on the gas then will not even start i replaced the fuel filter but that only help for a little while. if i let it sit for a couple days it will run for another 25 or so miles then do the same thing. this is driving me nuts since it is theonly vehichle i have and it supposed to get me and my girlfreind to work. please help even thoght i'm still blue i''l be orange whenever my truck stops stealing all my money being a peice of [censored] /forums/images/graemlins/frown.gif
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Do you have any trouble codes? /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  3. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Kinda sounds like what my truck did when the ignition module under the distributor cap went out. Did you check the spray pattern on the injectors? Sorry I can't be of any more help. /forums/images/graemlins/k5.gif
  4. new2k5
    Dec 16, 2002
    128
    south eastern PA
    th check enginelight comes on when it starts to stall.
    i dont know how to check the spray pattern. i am kinda mechanicly retarded. i can replace just about anything but diagnoseing problems get me baffled
  5. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    To check spray pattern remove the air cleaner and housing, and look at the throttle body while the truck is running. You should see a fine wide spray of gas coming from both injectors. What codes do you get when it stalls. The codes are stored until you disconnect the battery. The check engine light will only come on when the problem is present, but it will store a code even if the problem disappears. /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  6. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    i know exactly what the problem is, my 87 GMC jimmy was doing the same thing. If it is not your Ignition module. Then it is most likely that you have a faulty ECM (computer). Check all connections at distributor and coil. But i have a feeling it is your ECM.
  7. Khi5in
    Khi5in Registered Member
    Mar 19, 2002
    46
    Medford Massachusetts
    Just some input from a mechanic. If you want to diag this correctly, you need to duplicate the problem. When it stalls and won't start check to see if you are losing spark or fuel. If you have no spark start with the module and distributor pickup, as this is a lot cheaper than the ecm. And ecm's are pretty bullet proof on these trucks. If it is a fuel problem there are too many tthings to explain how to check for a non mechanical guy but a fuel pressure gauge is where to start. Could be a fuel pump, fuel pressure regulator, injector leak down, among other things. good luck, let us know what you come up with. If I can be of more help you can e-mail me.
  8. new2k5
    Dec 16, 2002
    128
    south eastern PA
    i dont know what codes i'm getting. the part that kills me is yesterady i couldn't even get it out of the driveway this morning it started right up and i drove it 10 + miles to a mechanic wit no problems. i'll let yall know what he says. i hate to pay someone but i really need my truck.
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    My guess is ignition module or fuel pump. The ignition module is very easy to replace, the fuel pump on the other hand can be a bear to replace, (ask me how I know). Does the truck shut off like someone reached over and turned the key off or does it kind of fumble then die? If it feels like someone reached over and turned the key off then it is probably the ignition module, if not then the fuel pump.
