Stalls after warming up...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by brian, Jul 13, 2001.
  1. brian
    brian Newbie
    Feb 18, 2000
    3
    I was wondering if anyone had any idea why my Blazer would randomly stall. It will drive until it is fully warmed up (choke pops off, full power, all guages stable) then suddenly die. Doesn't matter if it's parked or driving or in any particular gear. Then, after it cools down for about 15 minutes it will drive for another 5 minutes before it dies again. The engine is stock and I didn't make any changes before this started happening.
    My feeling is that the problem is either a heat short or vapor lock. However, I have checked all the wiring and it seems fine. Also, I drove over the mountains into the desert last week and the truck ran like a top. No vapor lock going up 5000 feet. I would think that the climb in 80 degree heat would vapor lock it.
    Any other directions/suggestions would be greatly appreciated.
    Thanks,
    Brian
    '72 K5 350/TH350
  2. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    do you have a electric choke, and have you looked at the points in the distributor.
    k5blazerus
    IF its not broke , break it and upgrade it.
  3. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    A bad coil sometimes will break down when hot, as well...
  4. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Could be trash in your gas tank. I've chased similar problems a couple of times, going through all the systems, only to find out that there was rust scale or other stuff in the tank. It collects around the pickup screen when the fuel pump is running, and then clears out after sitting for a while.
    Check your distributor lead too. If it is the original, the insulation might be cracked off just inside the housing. This was the case with mine many years ago and it behaved the same way (appeared to be heat related). It wasn't obvious because the wire appeared to be fine from the distributor to the coil. The right combination of heat and moisture would shut down the engine like a grounded anti-theft switch.
