Stalls out on me randomly
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jan 6, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    i have a 1989 GMC fullsize jimmy and for some reason it likes to stall out on me randomly, it usually happens when i come to a stop light but only after ive been sitting there for a while, i just put in a new throttle positioning sensor, is that the problem? somebody help me please /forums/images/graemlins/k5.gif
  2. pfloydmaster
    pfloydmaster 1/2 ton status
    Mar 30, 2002
    156
    Grottoes, Virginia
    Had the same problem. Turned out to be the battery cable to the starter.Cleaned the cable stud on the starter and replaced the cable...haven't had a problem since.
  3. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    It may be the fuel pump going. Does it start up imedeately after or do you have to crank it quite a bit before it fires up?
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Have you looked for vacuume leaks yet?
    Eric
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Was it doing this before you installed the new TPS? Did you set the idle voltage correctly when you installed the TPS?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If your truck has a lot of miles on it, you'll want to do this one anyway...Idle Air Control...its on the TBI, jsut a sensor that scres in. Might be that when its idling it gives a bad reading, tells the comp to lower the RPM's till it dies. Even if it doesn't fix the problem, you'll have a nice smooth idle...also check ignition module, mine did that kinda stuff when it was on its way out.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The Idle Air Control motor isn't a sensor. It's a stepper motor with a pintle on the end. The computer senses RPM directly from the distributor, then uses that data to tell the IAC if it needs to drive in and lower RPM (make the air bleed past the throttle plates smaller) or drive out and raise RPM (make the air bleed larger). The IAC motor doesn't send any information back to the ECM. Each time the engine is started, the ECM drives the IAC motor all the way in, so that it knows where it can start counting the motor steps from. /forums/images/graemlins/cool.gif However, a stuck or broken IAC motor can cause the motor to stall at idle. But it's a rather expensive part to just randomly replace as a troubleshooting step.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My IAC was only about $20 but it was at autozone...idle had been really bad, stalled on occasion, and wouldn't pass inspection
  9. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    i have to crank it for a little bit and give it some gas to get it rolling
