stand alone computers?
Discussion in 'The Garage' started by eightyone, Dec 28, 2006.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    does anyone know where i could get a computer for a 2000 6.5L? i heard you can get a stand alone computer for them. im outting a 6.5 in my 78 crew cab, and i found a motor and tranny, but it doesnt come with the computer. any help would be awsome, thanks.
  2. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    It would be pretty easy to do it yourself, just have the dealership flash out all of the security programming, and then next you have to rewire the wiring harness to eliminate everything that wont be used like abs stuff. I have no idea what all would need to be modded though for a 6.5 to work well.
    Remington
  3. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    I have a stock PCM from a 2002 H1. That would work for you, its OBD2, and the H1's did not have any security (pass key, vats, etc) built into them. Just let me know.
  4. eightyone
    Apr 25, 2004
    292
    long island
    is that computer going to plug right in and work? if so, let me knwo how much you want. and where you are located. thanks.
  5. twodollars
    Jul 19, 2006
    49
    Wayne, MI
    That would be a plug and play operation. For best operation a TDC offset learn would be helpful, but not necessary. Fourty bucks and I'll ship it. If for some reason it won't work for you, you can have your money back. It is a take out from a running truck. Factory cal is 195 hp and 440 lb/ft. The truck used a center mount turbo, but the controller doesn't know the difference, as the sidemount and centermounts are both controlled using the same vacuum valve. I am in Wayne, MI (near detroit). Send me an email at two.dollars@hotmail.com for specifics if you want.
