Standard and Auto starters...different?
Discussion in 'The Garage' started by Ben B., Feb 11, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    Starter went out on my truck w/ SM465.
    Can I use an auto starter I have or does it need a different one?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  3. dyeager535
    26,977
    Not to lessen the previous advice, as long as they look externally the same, they will work.
    Had this problem a couple weeks back. Looked at 4 starters at LEAST, that were all stated as being for various 73-87 truck applications, not a single one of them was identical. Bigger or smaller solenoids, different length starter bolts (not cheap new, $6/each) cast iron or aluminum noses, bolt to bellhousing or block, staggered or straight bolt pattern, and so on.
  4. sullivan8
    sullivan8 Banned
    Dec 14, 2010
    16
    USA
    came across this post because i too am experiencing the same predicament. i only have these starters for another vehicle and i just wanted to ask if this would work for my truck.
    yeah they look quite similar. so i assume you're also advising me to go for it. thanks!
  5. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Older trucks with the SM465 used a different nose made of casr iron,on the starter,that bolts into the bellhousing instead of having the usual 2 bolts into the engine block--but you can take the nose off the old starter and swap it right onto one meant for an automatic...
    I once got a 350 engine free that ran perfect,but the guy who removed it had a mishap,it fell off the engine hoist and landed on the starter,and a chunk of the block busted off where the outer starter bolt went...it was a sweet runner,but useless as far as being able to bolt a starter to it ever again,it couldn't be welded--but my truck had the SM465 that used the bellhousing mounted starter,so it didn't pose any roblem for me to use!..:D
