Start of my Small block onboard air bracket for a york! Update 3/16
Discussion in 'The Garage' started by backyardbuilt, Mar 9, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Decided to finally go for it and got the part mounted to the motor figured out the easy part will be mounting the part that holds the york. I used a modified new style power steering bracket to clear this bracket and have a dual pulley pump to run the york.
    Front of bracket
    Side of bracket
    Back of bracket
    Bottom of bracket
    Close up of bracket
    The bracket is held on by all three bolt holes in the head and a 4th that the power steering bracket has up by the header. I am gonna weld a flat plate on this bracket with slots in it for the york to tension the belt it will look like a T from above.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: Start of my Small block onboard air bracket for a york! PICS
    man those are some rusty headers /forums/images/graemlins/yikes.gif
    braket looks good so far. mine is gonna mount preaty much the same way. /forums/images/graemlins/waytogo.gif
  3. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    There not that bad some of it is burnt on mud but they are 7 years old, thanks about the bracket.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've only gotten as far as making the york base-plate and tension adjuster on mine.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Umm, I have the York and a tank, that's about it /forums/images/graemlins/rotfl.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't feel bad, mine are three years old and coated and they still look like crap.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That is roughly what my York Bracket looks like. My tensioner pulley is actually mounted on the side of the York itself. I just crank it out to tighten up the belt. I run it the same way with the extra slot on the power steering pully. It has worked well for years.
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I'm gonna use the york bracket for tension no pully the bracket will be slotted to move the york for tension. Going out to finish now I hope.
    Not too worried most people never see in the engine compartment anyway, just the privalidged CK5'ers
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Got it done just getting the right belts and then wiring and hoses for the air and misc. stuff.
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    wow, you did a side mount plate? I made a plate for the base so the york can SIT on and not hang from. not going to have any vibration issues doing it that way are you?
  11. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I would definately add some sort of gusset to your mount or other support on the york itself. Trainagulate it some how.You have a lot of load going on the front of the york from the pulley.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Exactly, I was going to see about coming off the back of the york to another location on the head towards the back.
  13. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I haven't made it yet but there is gonna be a solid bar coming off the top going back to a header bolt on the back. I have run it without it and it vibrates but not as bad as I thought it would. I also have another bolt to put in that holds it in the middle from the power steering bracket that bolts to the header on the back side 3rd pic down you can see the bolt hole.
  14. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Went a little different on the support brace went to the brake booster instead looked easier. First pic shows the bracket and second shows it running no vibration at all. That thing puts out alot of air should fill up my two 7 gallon tanks quickly.
  15. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the only problem i see with putting the support on the booster is the motor moves independtly from the cab. when you get flexing, the frame is going to go down, the cab go up and when you step on the gas, the motors gonna move /forums/images/graemlins/yikes.gif
  16. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Your not supposed to think about it like that, oh well guess thats what happens when your thinkin about your dog running away more than what your working on. Back to the drawing board. On a happy note found the dog though.
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Since running that support brace to the header bolts would be the easiest way to go, but also be bad. Bolts get ruined easier due to the heat of the headers, prolly leak more. What about running the brace off one of the intake bolts?
  18. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    They did it that way on pirate with a piece of round stock bent up and around. I think I'm gonna use the same type stud I did for the power steering bracket on a head bolt location and just swing the bracket I have down to that location should work fine, I'll know tomorrow, day off that is after the parade the wife wants to go to.
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Why not get one of the factory "wing" braces from an old log style compressor. Already sized to fit down on 2 of the intake bolts, bent to clear the valve cover, sturdy, cheap, and well triangulated. Might need a small extension, but no biggie... I saved the one off my son’s truck for that very purpose. /forums/images/graemlins/laugh.gif
  20. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    So how powerfull are these yoke compressors? I'm thinking about a power converter and one of those pancake air compresors just to pump the tires up, can you run power tools on the york? I was just thinking about an electric impact and running it off the power converter or a near by plug in.
