Start-up puff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Jul 26, 2000.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Well, usually when starting up first thing in the morning, my Jimmy lets out a little puff of blue-ish smoke. I've been told that it's the valve seals. Anyone think otherwise? Any half-assed fix without major surgery? - Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
  2. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    Oh Yeah
    Thats the valve seals. If you have an air compressor you can change them without removing the head. Also heard you can do it with a rope but I would never do it. Shops gonna charge you 200-300 to do it.
    Peter Schneider
    81 Jimmy
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    It is the valve seals, would not worry about it till it gets bad. But it is easy to do if you have an air compressor. My 89 did this for 5 years never caused any problems.
  4. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    ditto DMK....except 6 years now
    SteveB
  5. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    mine, too
    <font color=purple>delta9blazer</font color=purple>
  6. shadetree
    shadetree Registered Member
    Jul 25, 2000
    10
    Missouri
    I am new to this forum, but I have seen this topic a million times, as I am sure others have. It is definitely the valve seals and my daily driver has done this for 10 years now. I wouldn't do anything about it until you have another reason to take things apart. My puff of smoke has not caused me any problems and it helps kill mosquitos. I'll admit, though, it is a little embarassing when it blows back into your girlfriend's face. I have never replaced only the seals, so I cannot comment on how difficult it is with the engine in the truck. But other than a little annoyance, you should be able to drive it for long time with the puff. It is an engineering flaw on the older factory heads. If you start burning a lot of oil, though, it may warrant your time and $$ to fix them.
  7. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    My K5 has done it for a few months. My radiator developed a leak on a long trip - overheated and ever since - ppof!! blue smoke every morning. My wifes vortec S10 Blazer did it too. Fixed the S10 for $100.
  8. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    valve guide seals. you can buy a puller for it where you dont have to remove the heads or use compressed air. if your truck is more than 10 years old i would replace them all because once one rots out they all follow quickly
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Keep an eye on your plugs..........The oil that gets through the seals can foul them a lot faster. I've been a member of the "Puff-O-Blue Club" ever since I bought my truck, and other than replacing my plugs once about 3 years ago, there haven't been any other obvious complications- Other than the embarassment of "Hey bud, your truck's on fire" comments!
  10. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    Mine does the same and I am about to put new plugs in it, anyone try those Bosch platinum plugs, and are they worth it?
    If it aint a Chevy don't raise it up!
