Started De-Ghettoizing My Interior Today
Discussion in 'The Garage' started by ARAMP1, Nov 13, 2006.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I figured I'd show off what I did on my day off today. I've had this project going for a while and finally decided today was the day to start. Basically, I covered the inner and outer door skins in B-Quiet Ultimate and put on some diamond plate aluminum panels. Well, one down, three more doors to go.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Look's good.. I like the idea,but I'm going to use some thin gauge steel,and paint it. :wink1:
  3. littleryno32
    littleryno32 Registered Member
    Jun 27, 2006
    27
    Willis TX
    Cant see the pic, but anyway does anyone make the diamond plate panels or did you make them?
  4. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I measured out the sizes and shapes and had a guy cut them.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That looks great. Why did you cut out the bottom section?
  6. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Convenience really. I needed a way to mount the bottom panel and cutting it made it easier to mount the clip/nuts. It also made it easy to apply the sound deadener material.
  7. cbbr
    Jul 17, 2004
    14,681
    Makes sense. Looks like a good place to mount a speaker now.
    Post up when you get done, I would love to have a real world appraisal of the sound deadener.
  8. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    looks amazing. One question, where did you get the sound dead'ner? I will be wanting to pick some up when I do my crew cab swap definitely. Any store chains that carry it or something similar?
    Remington
  9. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    so how much weight did you end up adding to that door?..
  10. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    It’s hard to believe, but I can really tell the difference in just one door. I’m not sure how much weight it added, but you can tell the difference when you close the door. It’s definitely heavier and it sounds a lot different when you close it too. I got the stuff on e-bay. It was just over $125 shipped for 100 square feet. The stuff is called B-Quiet and it’s supposed to be quieter than Dynamat. Their website is www.b-quiet.com. There are a lot of guys on other street car/truck forums that swear by it.
  11. cbbr
    Jul 17, 2004
    14,681
    How much of your rig will that cover? You using 1 layer or 2?
  12. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Right now, I'm only doing one layer on each panel, however the outside panel is getting a layer and the inside panel is getting a layer, etc. I might do a double layer on the firewall and floor, but I haven't decided yet. Right now, I've probably got enough stuff to do two more doors. Yeah, I know. That's not a lot for the money. For me though on my daily driver, it's definitely worth it.
