Started fender trimming today
Discussion in 'The Garage' started by jjlaughner, Aug 4, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Atta Boy! Look's like Your taking the "tare" weight down too, by the look's of all that dirt that fell outta there! /forums/images/graemlins/grin.gif
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    That ain't dirt, thats RUST! /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    [​IMG] (edit added pic)
    Thats the PO's brake lines job, No wonder I had to pump the brakes a few times to get them to work. All the brake and fuel lines will be re-ran before the new tank goes in.
    Then HOPEFULLY /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif In September sometime HarryH3 and Kenny W are setting me up with a new FRAME!!!!!
    Thanks guys, make all the other work seem a little more barable now /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Here's the gas tank that came out
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what kinda tires you gonna run? size wise?...that a 12 bolt rear??
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    By the look's of all the rust, They must really dump what Salt? on the road's back there! Man I thought CG90 was bad. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    the scary thing is that rust doesnt look " not normall" lol to me..lol
  8. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That looks kind of like the pile of crap I sweep up after doing anything with my 'Burb....
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    This truck is running 31's, its plow truck. I dont think its a 12bolt, its just how I bought it, I haven't done anything mechanical to it besides putting a rubber line on the return for the power steering pump (temp fix, the old line rusted out and popped, as did all the fuel and brake lines, that why they are the flex tube stuff that hanging down). /forums/images/graemlins/tongue.gif
    As far as what I'm going to run, when the new frame gets here I got a 14bolt with 4.10s that's getting disk brakes, then I'm going to slap some 36's on and swap the body onto the new frame. /forums/images/graemlins/thumb.gif
  10. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    You better get back to work! It is only a matter of time before you put 35's on it. Go ahead and cut up more in the back (less drag) up to your tail lights. More in the front as well, back to the firewall. And why did you take your bumpers off? Those things are easier to cut through than the sheet metal! It's a style thang (as in I ain't got none)
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    EVERYTIME! If you close the doors hard, if the wind blows funny, close the tailgate... It rains rust. After I cut out the fenders and someof the floor pans its not as bad. But I do get BOXES of rust to setout for the trash guys once a month /forums/images/graemlins/eek.gif /forums/images/graemlins/blush.gif
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    NEXT SUMMER! When it goes onto the donor frame I'm thinking tubed front fenders with the factory hood and narrow the grill /forums/images/graemlins/grin.gif.
    Other plans are replacing the rockers with tube, removing the fiberglass top and either doing a ragtop or full convertable (that all depends on if the barn gets build this fall). Otherthings might be some body armor since I got alot of rust on the sheet metal, some threw like where the badges where.
    As far as bumpers, it was all bent up from the PO hitting something, I had to cut the tank bolts (to replace the rusted out leaking tank) and since I had no torch I had to remove the bolts with the cutoff wheel, to get to those bolt the bumper had to come off so it had to be cutoff too. The licence plate is getting mounted to the tailgate and I'm thinking 2"x4"x 1/8th wall tube and making my own brackets to mount and clevis mounts also. I would like to run the exhaust threw the bumper like the old MO offroad blazer. I have a lot of 'PLANS'. Just need to find a job to make them happen. /forums/images/graemlins/smirk.gif
    I have a D44 with 4.10's and I'm building the 14bolt with disks, 4.10's and locker to hold the 36" TSL's I'm wanting on some simulated beadlocks I'm thinking up (just need to find someone with a plasma cutter).
    It going to be a cruiser and light trail rig (since I feel bad when wheeling the DD), none of the fun stuff like big rocks and vertical climbs /forums/images/graemlins/rotfl.gif
  13. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think the 3rd picture should be on the front of CK5 you see the cut fenders anglegrinder sawzall and hammer all in one picture /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Confedneck thats a 10bolt
  14. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I second that! /forums/images/graemlins/cool.gif
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thumb.gif That would be funny!
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah I should admit, I just bought the truck about a year ago from a guy in Northern Ohio up by the lakes. They do salt the hell out of the roads here too though (and they just started using that liquid stuff).
    But this was a plow truck up north for all of its life. I think it was a on a dealers lot. There was no registration on in before about two years ago when the other guy bought it and titled it, but it passed emissions and there were records for it just no ownership. He bought it with 77890 on the title and I bought it with 78100 on the title (it only has about 78190 on it now).
    Other than the really rusty frame the body is only a little worse than my other blazer was when I started restoring it (only difference being the rear fenders and radiator support on mine had very little rust).
    The plow truck is not getting restored but its getting saved. I'm going to do all the body work I can without buying to much other than grinding wheels and paint (I might buy the full bed floor because its about gone and needs the tailpan). Then next summer (after I use it to plow this winter) its getting dropped on a frame HarryH3 is sending me. Hopefully by that time the frame down work will be done. I'll do the bedfloor and paint the outside (hopefully will have most of the rust at bay by then )
    I wouldn't have bought it because of the rust, I won it on ebay, but when I got there it looked like the bad things (axles, springs, rockers), when the things I was going to replace or cut off. If I would have looked at the rear floor and frame a little closer I dont think it would be sitting in my driveway /forums/images/graemlins/deal.gif /forums/images/graemlins/tongue.gif
  17. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    [/ QUOTE ]OMGosh!! That's a lot of rust! Have fun cutting bolts, rather than loosening them up. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  18. joshua
    joshua Registered Member
    Jul 31, 2003
    5
    What are your plans for a gas tank??
