started making my bumper update 9/15(pics)
Discussion in 'The Garage' started by rdn2blazer, Sep 1, 2005.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    that free steel that my boss gave me a while back was starting to bug me just sitting on the garage floor so i got started on a front bumper for my 89' 4x sub. i did a search for winch dimensions but came up with nothing. anyone have plate size and hole spacing for say a 12,000 lb winch. not sure which model but it will probably be a warn since i can get a pretty good discount through a buddies shop. please feed back, thanks.
    i cut the taper pie cuts on the band saw and welded one side at work on this past friday then brought it home to finish welding the other taper up. then i made the verticle cuts to taper it back to give it a three dimensional look. dont like that flat board look with these type of bumpers. i will cap the cuts with plate bent at the same angle as the bumper that will have six 2 1/2 holes to plug weld plus around the edge ofcourse. dont want to weld the back taper up until i know the winch mount size to i can set the back taper properly so its mounted high and tight. what ya think?
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Looks good so far...can't wait to see the finished product.
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Nice
    Looking good. I need to start on mine.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nice fab work, welds look great!
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Hey, is that 2x8x1/4? That is what I used for my bumpers. I just left mine straight though, looks like the same taper on the ends.
  6. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I've seen you say this a few times... Why dont you just pony up and get a membership? :rolleyes:
    John
    edit:
    Bumper looks great!
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Looks good!
    If you go to www.warn.com They have mounting dimensions of their winches on-line!
  9. TLCOR
    Aug 16, 2005
    333
    At ya mama's!
    Beacuse I spend my money on fuel and steel, if you would know the fuelprice in this country Im sure you would understand ! :D
  10. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    ok............. :rolleyes: :surepal:
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    looks really good. Like that a lot more then most tube bumpers I see.
  12. rdn2blazer
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    thanks guys for all the props. tlcor, i will as soon as i can, im at work right now and my breaks are short. im going to add a stinger and side bars and light tabs too when im at that point in the build. i didn't want to loose the radius on the bottom so thats why i didn't just cut the bottom off and cap it. i will also cap the ends with the same radius so it all matches. yes it is 2x8x1/4 wall. a couple more pics. i also "v" grooved the seam to be welded for better penetration.
  13. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Good lookin' start! U gona seal it up good and use it as an air tank too?
  14. rdn2blazer
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    hadn't thought about it, but thats not a bad idea. i have seen it done before. i guess it shuold be plenty strong enough after i am done, right? it doesen't seem like a whole lot of volume though. im gonna have a onboard air compressor, probably something like a oasis.
  15. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    we don't understand.....noone here buys steel or gas :dunno:
  16. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No not us... :rolleyes:
  17. TLCOR
    Aug 16, 2005
    333
    At ya mama's!
    Sure you dont. ;)
  18. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Dooooh :doah:
    Really if for anything I got mine to help keep this board alive. No way it would stay around if there where no members to help out. I got my money back the first tech tip that saved me a trip to any mechanic.
    Great job on the bumper. Keep us updated.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    sorry to hijack but what is the cost of fuel there?
  20. senatorwoodhouse
    senatorwoodhouse 1/2 ton status
    Jan 22, 2005
    108
    des moines, IA 50311
    Looks good!!!!!!! wanna build one for me? :D
