started my 465/205 swap last nite.
Discussion in 'The Garage' started by colbystephens, Jul 19, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'm happy last nite was the last time i'll have to be swimming thru auto tranny fluid to work on my rig. :D dropped my 700/208 combo last nite. discovered the wonders of removing the tranny hump and using a cherry picker too. if you have the opportunity to use a cherry picker for that purpose, i'd definitely highly recommend it. it is SO much easier than using 4 floor jacks. :doah:anyway, i'll post up a pic later and maybe i'll just update this thread a bit as i do the swap next week. ;)
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    You'll love a 465 with a diesel:D
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's what i hear. :D
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    nice! im deadlocked in my swap right now lol.
    good luck mang
  5. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Of all the projects (both failed and successful) done with my rig, the 465 swap has been by far the best...Good luck!
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'm scraping the th350 in my 72 in favor of a 465-205 behind my 6.2:D
  7. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    the cherry picker works great.
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Im swappin in a 465/205 soon too. no cherry picker, no jacks and stands. me and my 2 big buddies are gonna pick it up and set on the cross member cause there'll be no body cause its getting swapped at the same time too. Ill get pics up when we do it. good luck on yours.
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Glad to hear you're doing the swap. That sounds like much better talk than getting your auto worked on...
  10. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Me and leper had the perfect contraption for this!!
    Take a large ratchet strap, pull the tranny tunnel, hook 1 end on 1 rocker and the other end on the other rocker running it under the tranny. Use the ratchet to hold weight like a pully.Pull all bolts and everything, 1 person pull back the tranny off the converter, while another person hold the strap through the "pully". The person holding the strap slowly let it down, it will start to tilt, perfect way to drain it out the dipstick hole. Have the person under the vehicle start working the tranny so it will sit flat. And youll have it out without breakin a sweat!
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, now i got a problem. the shift pedal is from a mid 80's truck (85ish?) (tRustyk5's truck) and it seems the pedal set up is different from mine (83). rene's truck had a big collar type deal which a big long bolt went thru which held the brake and clutch pedals up, mine does not have this collar - which is funny since my buddy's 84 automatic k5 had a similar set up to rene's. how can this issue be remedied, in other words, how do i hang this clutch pedal? i need this taken care of ASAP!! :) thanks!
  12. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Sorry man, all I know is that the under the dash bracketry from an early model (pre 1973) is differnet from a late model (post 1973), however I have never looked at anything as new as mid 80's...
  13. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    sweet. I think you may have just made my next 2 days easier. thanks:bow:
  14. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    i will look at my old mans burb were doing a manual swap he pulled the pedals out of his 82 k5 and put them in a 78 burb he didnt say anything hmm
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It's an '81 Colby...
    Rene
  16. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I don't know which one you have, so here's both mechanical and hydraulic. If you need, I can take some pictures. This is from a 90 R/V which should be the same as 80-87 C/K.
  17. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Dude, it's such a mess under my dash, it's unreal. Anyway, here is probably the best pic of the clutch pedal (firewall towards the top of the pic) that I'll get without taking stuff apart.
  18. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That is a hydro clutch, Colby is trying to install my old mechanical clutch pedal and linkage.
    Rene
  19. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
  20. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    I have one of those and its a total piece of crap.... but Iv probably removed and installed ten trannys and transfer cases with it and it is at least 27,496 times better than nothing... or trying to balance the trans on a floor jack.
