Started replacing body mounts today..nedd some quick help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stickseler, Nov 9, 2002.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I started to replace my bodymounts today and install the 1" body lift. I got the front 6 bolts loose and the washer thing on one is rusted through (it fell off while I was losting the bolt). The rest arnt in the greatist shape /forums/images/graemlins/confused.gif Where can I get a new set quick??
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    are you talking about the washer thats in the cab? the one that the bolt comming from the cab to the bottom of the truck...square hole.....get some 1/8" sheet metal at home depot and bend it to the shape of the floor board...
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    You're talking about the steel washer-thingies with the rubber body mounts? If so, LMC Truck has them as replacements for fairly cheap. /forums/images/graemlins/thumb.gif
  4. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I think your talking about the kinda cupped washer thats on the bottom of the bushing that the head of the bolt tightens against? If you are I got mine from LMC, they where pretty inexpensive. You might try your local dealer also.
  5. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Nope..the half a doughnut looking one on the bottom. Its on the one that has a bolt going up through it. It the middle mount on the pass. side
  6. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    yea that one
  7. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    I guess my trucks grounded for the week /forums/images/graemlins/frown.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMC sells the bottom part of the washer for something like $2.95 each.
    If you need the upper part which slides into the bushing, you cannot buy them separate from the bushing. Have to buy the rubber with it as its sold as one part. /forums/images/graemlins/tongue.gif
