Started the install
Discussion in 'The Injection Section' started by vtblazer, Jul 24, 2006.
  1. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Pulled the carb a couple weeks ago and as time permitts I'll get this thing done.
    It's a TPI set up from a 1986 Corvette.
    MAF system, with the 22lb injectors.
    Any input is welcome, good/bad or indifferent.
  2. dyeager535
    26,982
    191
    If you want to simplify the wiring, if it wasn't already, you may consider switching to the one piece oil pressure switch/sender, as opposed to the separate ones the trucks used. Made my install easier, as I was able to locate that down above the oil filter.
    Otherwise, just get familiar with the wiring and look forward to how it will run when you are done!
    You'll certainly want to learn to burn chips, or pay someone else to do it (my least favorite option) to make sure it runs as good as it can. A corvette engine is going to be much different than what you are running. (assuming you only have the TPI parts, not the engine itself)
  3. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
  4. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Thanks,
    The whole package came off of another running 67-72 truck but it was a pavement pounder, so yeah burning another chip is a must.
    It's not the Corvette motor unfortunately but it is a fairly low mile GM 355ci crate motor that runs pretty strong.
    eagle mark, good info, I'll read up on it, thanks.
  5. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    keep us posted with the progress!
    i'm putting a TPI on my crate motor before i put the motor in my truck
  6. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Going slow due to time but moving forward.
    Changed the computer mounting location from under the passengers seat to behind the glove box door.
    Had spent close to three days trying to make the under the seat location work though...:o No room, water issue's and access made me decide to move it.
    Took the time to instsall an electric fan while I was in there and if time permits, a serp set up is waiting as well.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Looking good! Just be aware that if you decide to go with the serpentine belt system that it has to be one from a TPI engine. The TBI brackets are different and get in the way of the TPI intake. :(
    There are a few pics of my TPI swap on my site at:
    http://www.angelfire.com/super/ThunderTruck/
  8. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Whoa...good info to know, thanks. :bow:
    I was about to send off a M/O this a.m. to get another one.
