Started the steering box reinforcement.***Finished with more pics****
Discussion in 'The Garage' started by Esteban86K5, Feb 11, 2004.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    So I started the boxing in of my frame yesterday. I only tacked it all in place cause I want to drill the holes and do some fitment test prior to welding it all up. Whatcha think?
    Before
    After
    Here are the pics of the finished product. I am really happy as to how it came out. I feel it's a hell of a lot stronger than stock and should eliminate the cracked frame problem. /forums/images/graemlins/thumb.gif
    Here are the full set of pics. /forums/images/graemlins/waytogo.gif
    Full set of pics
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Re: Started the steering box reinforcement.
    looks good
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Are you boxing the inside?
    What about the outside?
    Looks EXCELLENT!
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Looks EXCELLENT!
    OUTSIDE??? Outside of what??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    It's not an I-Beam... /forums/images/graemlins/tongue.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Looks very good, I like your work. /forums/images/graemlins/thumb.gif Are you going to need longer bolts now that hold on the box?
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    hmm add to favorits list'
    really need to beef mine up to, the 38's were hell on my frame, I have a c-channel in my c-channel frame /forums/images/graemlins/eek.gif
  7. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    It looks like he is boxing the frame. I thought the problem with the frame is the thickness and brittleness of the frame metal.
    The kit I got from Rough Country many years ago, welds their plate to the outsie of the frame. This in essence makes the frame thicker and stronger.
    I suppose boxing it does the same thing. It puts the strnegth into a box, instead of a single plate.
  8. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Good start! why not go all the way
  9. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I want to know where you got that electric fan kit??? and what it costs? /forums/images/graemlins/waytogo.gif /forums/images/graemlins/thinking.gif
  10. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Looks alot like my fan set up from flex-a-lite. Mine cost me $500 for a dual fan and a adjustable thermo control box.
  11. Esteban86K5
    3,712
    Bakersfield, CA
    I am boxing in the frame which will take away the stress off the single side and distribute it to 2 side. I am drilling the old mounting holes to 3/4inch then welding in a 3/4" .120 wall tubing on both side. This will make both the outer frame and the new plate one STRONG piece.
    I did need to get longer bolts. I now have 2 at 3 1/2 and 2 at 4" I should be done with it by tomorrow so I'll be posting more pics.
    And Steve, the crossmember seemed to be stong enough as it is so I just decided to strengthen the weak spot only. /forums/images/graemlins/waytogo.gif
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    That is a BlackMagic M150 Flex-A-Lite fan, well at least it looks identical to mine and that is what I have. Do a search in google you'll find it /forums/images/graemlins/thumb.gif
    The are 2800cfm too /forums/images/graemlins/waytogo.gif
    EDIT>>.Opps that is not the M150 I didn't see both of them at first!M150 is only ONE fan /forums/images/graemlins/rotfl.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/doah.gif That is a FlexAlite though....
    Edit #2 it might be Two M150s???? They do have seporate shrouds????
    Lets here it Frizzzbeeee? /forums/images/graemlins/ears.gif
  13. 4xcrazy
    Oct 31, 2003
    9,472
    5
    so theeeen that would make it a m300 then,,,right? /forums/images/graemlins/tongue.gif
  14. 85m1009
    Jul 11, 2000
    718
    Missouri
    The stock crossmember is plenty strong, I added the 2 x 4 tubing and boxed both frame rails since it was accessable with the engine out. I am also planning on using the crossmember as a partial support of the new hidden winch mount bumper in the works. As far as the fans, they came with the truck. I think they are flexalite fans though I am unsure of the model. They do work extremely well almost too well. My 10:1 383 runs about 150-160 degrees in the hottest weather with the a/c on. This time of year it barely breaks 120 and I have not even heard the fans turn on for several days due to the cold.
  15. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Wow. /forums/images/graemlins/ooo.gif
    Awesome. /forums/images/graemlins/waytogo.gif
    I suppose I should do the same thing. /forums/images/graemlins/1zhelp.gif
    I guess I never heard of boxing the frame at the steering box.
  16. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Sounds to me like you need to check out that thermostat then, try runnin the 195 in the winter and 180 in the summer, always worked for me in my old car. Oh well, i like those fans, going to have to see if i can find some. /forums/images/graemlins/waytogo.gif
  17. Esteban86K5
    3,712
    Bakersfield, CA
    new pics up top. /forums/images/graemlins/thumb.gif
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You do know that you should "fish mouth" it where it ends to keep from having a bad stress concentration....
    /forums/images/graemlins/whistling.gif
  19. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Monday morning Quarterback /forums/images/graemlins/doah.gif
    Looks good Esteban.
  20. Esteban86K5
    3,712
    Bakersfield, CA
    Do you mean like this?
