Starter and Tach
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JW86, Aug 4, 2003.
  1. JW86
    JW86 Registered Member
    Aug 20, 2002
    40
    Bolivar, Texas
    Hi. Need a little help here. When i turn the key to start I get a click, try a few times and it starts... assume this is a starter issue, but today, my Tach does not work?? could this be a wiring problem ? Would the two problems be related or not? Just replaced the alternator. 86 305 Manual Trans. Any advice appreciated, dont want to change the starter if i can avoid it, same for the tach. I assume the tach is run electronically from the distributor, and not a cable type set up?
    Thanks in advance!!
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well if it is the starter then it is the solenoid... try jumping it with a screwdriver... areal pain but it works... if everytime you jump it, it works.. then your starter is bad. the tach just might be another issue all together....
