Starter bolted where?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TED, Feb 23, 2004.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I have a 70 with a manual trans and cast bellhousing. I was informed by a fellow CK5er that the starter is supposed to be bolted to the bellhousing, mine is bolted to the block. No signs of improper wear on flywheel teeth, anyone else have a similar set-up? My starter is the cast nose cone kind.
    2 possibilities here:
    1. 2 different kinds of starters
    2. Im freaking retarded and in no time I'll be removing a heat shield, header, and starter.
    /forums/images/graemlins/hack.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yes, there are two different types of starters. Yours should have originally been mounted to the bell housing. The block mounted starter you have now will work fine, and it is a much more common type of starter so they are easier to find. Just be careful if you try to buy a new one.
  3. TED
    Nov 27, 2002
    81
    San Jose, CA
    Thanks Tim, I feel a little better now. I've had starter problems in the past and I thought maybe that was why. Now that I have a starter brace and heat shield, no problems.
  4. Blazer1970
    1,600
    Old Mission, MI
    You should be good to go. /forums/images/graemlins/cool.gif
