Starter brace
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TED, Jan 14, 2003.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I had starter problems before I bought a new starter since I had a warranty on it anyway, but when I was having problems someone told me to get a starter brace. I got one but the hole that allows the bracket to be bolted on to the block is in the wrong place. Are these really necessary? I don't want to spend time customizing a bracket when I have so much other work to do on it.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    ??never heard of that??
    I have a manual so maby it is a slushbox thing??
    Good Luck /forums/images/graemlins/thumb.gif
  3. 72BlazerTravis
    72BlazerTravis Registered Member
    Dec 19, 2002
    55
    Jefferson City, Missouri
    No it's not just a slushbox thing. I can't get a starter to work correctly on my 4 speed. (works now that it's broke) A starter brace will help stabilize the starter and give it less situations for the gears to slip. On mine the bottom bolt (closest to the flywheel cover) is broken and for some reason even when i put a new starter in it gets jerked around when I crank it. Starter braces really do help keep it in line. /forums/images/graemlins/smile.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've heard of them but have never seen one. I wonder if you could make your own up?
  5. Burt4x4
    6,854
    Ahhh, Gotcha!
    Last year I put in a Napa starter and it is still workig fine. Is your starter after market or stock style?
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Here you go gentlemen.It helps greatly.
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Of all the starters I have changed and or seen.... 1 had the brace still on it!!!!
    I would put one on, keep the starter from trying to rotate.
    -Jeremy
    Soon to be a "/forums/images/graemlins/burb.gif/forums/images/graemlins/pimp1.gif"
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Hmmmm. I'm getting ready to warrenty my starter. Maybe I'll have to hit the dealorship and get a brace while I'm under there.
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Years ago I purchased one of those starter braces from PAW for about $5. These are cheap insurance in my opinion. One thing you'll need is a starter motor bolt that has a threaded stud that protrudes from the head of the bolt(kinda hard to describe). This stud hooks on the bottom of the brace and gets cinched up with a nut. /forums/images/graemlins/thumb.gif
  10. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Don't need one if you're using a light weight gear reduction starter... I've got a planetary gear starter in my Blazer and it works like a charm without the front housing brace. FWIW, I've got a brand new GPE gear reduction starter for sale...
