Starter engagement problem *UPDATE*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pure Insanity, Jan 7, 2002.
  1. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Heres the deal, I have a Vortec motor in my Blazer. I have it converted a carb, but thats beside the point. I didnt think anything about it when I ordered the flexplate, but I may have gotten a "smaller" flexplate. All was fine until about a week ago, when it started getting noisy and making a hillacious noise like the starter is kicking back out. Its getting worse and popping out more often FAST! I got under and looked at the flywheel and it looks like the ring gear is not getting good engagement to the starter gear. The block has the holes for both types of starter. (straight across and angled)
    Heres the bad part of the question, how do I find out how many teeth are on my flywheel w/o painting a tooth and counting them while I rotate the eng. by hand, or pulling the motor??? I am thinking I will end up having to paint a tooth, and count my way around.
    What are the 2 options of tooth count, and what do I need to order for a starter, when I find out? I am totally lost on this one. <img src="http://coloradok5.com/forums/images/icons/crazy.gif">
    If ya can't stop.......Smile as you go under! <img src="http://coloradok5.com/forums/images/icons/smile.gif">
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by pureinsanity on 01/08/02 05:04 PM.</FONT></P>
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Starter engagement problem
    if the inspection cover is off, just count one fourth(1/4) and times it, way easlier then counting every tooth..it sould be either a 153(1/4=38 teeth) or 168(1/4=42teeth). I was hopping that Summit would show the diameters of the two but it doesn't otherwise you could just pull a tape on it.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    The only prob is......how do I know I counted my way around 1/4 of the flywheel? Is the spacing of the teeth different on the 2? If so I could measure teeth per inch.
    If ya can't stop.......Smile as you go under! [​IMG]
    GO</a>
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    wise ass (i was wondering the same thing "hows he gonna know when hes done 1/4" but i wasnt gonna say nuthin)
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  5. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    If you give me the part number, I might be able to look it up. When I was picking my flywheel recently, I researched the heck of this issue and I think I have a pretty complete listing of chevy/gm flywheel and flexplate numbers and stats. Let me know if you have the part number.
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    The only thing I know is that there is a differnce between single piece rear main and two piece as -far as it relates to the flex-platel. I don't know if the diameter changed..
    Two-piece flex plate is the only thing I have on hand.
    - Dia is 45 inches. so a 1/4 of that would be 11.25 inches.
    I don't know if that helps, because it's a 2-piece rear main.
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
  7. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    also, you MIGHT be able to measure the diameter of the flywheel with a tape measure through the starter hole, a rough measurement. The size difference between the small and big diameters does not require an exact measurement to know what you have. OR, assuming it is an automatic (flexplate) you could take off the bellhousing cover and do some measuring counting that way.
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Lasvegas:
    See what you can find on a 96 and up, flex-plate. Look for a dia. and tooth count. I think that might help, if you could.
  9. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    twistzid, you have a 45 inch flexplate?
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    use a framing square and where it hits a tooth at one arm of the square to the other arm of the square...it will make a 90 and count the teeth between them.
    55 Willy's
  11. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Got myself all confused, now.. Radius?...thats not it, out-side diameter....?
    Whatever....
    I taped the out-side the flax-plate and its 45 inches.
  12. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    According to my stuff, the one piece started in 86. But there are still 12 3/4" and 14" after that. The smaller ones had 153 teeth and the larger ones had 168.
    Part No. Diam. Year Crank Flange Converter Bolt Tooth
    Bolt Pattern Pattern Count
    471598 14" 70-85 3.58" 10.75" 11.5" 168
    471578 14" 70-80 3.58" 10.75" 11.5" 168
    471529 12 3/4" 69-85 3.58" 9.75" 10.75" 153
    14088765 12 3/4" 86-up 3.00" 10.75" 153
    12554824 14" 86-up 3.00" 11.50" 168
    14088761 14" 86-up 3.00" 10.75" 11.5" 168
    The above info is from the GM performance parts book. Hope this is some help.
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Circumfrence!!!!!!
    Give me some slak, My frontal lobes clocked out hours ago..I'm working on instincts now..
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Wise ass????? " It's better to remain silent and be thought a fool, then to open your mouth and remove all doubt."
    But all in all your post was very informative[​IMG]
    55 Willy's
  15. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    Isn't radius equal to 1/2 Pie squared or something like that. That should be easy to back out your diameter. But 55Willy's idea would work excellent too.
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    O.K. so to put this all togather, we come up with...
    A 14 inch diameter flex-plate, would have a circumfrence of 45 inches, a 1/4 of that would be 11.25.
    So, measure 11.25 inches around the flex-plate and count the teeth.
    *I came up with 42 teeth, so I have a 168 tooth flex-plate.*
    Now what happens if the diameter is 12 inches? I don't know.
    But useing Lasvegas's chart, the 12 inch flex-plate has 153 teeth.
    Both 14" plates have 168 teeth.
    If Steve measures his, and the measurements come out like mine did (above).
    Than it's a 168 / 14" flex-plate and Steve is screwed.
    If they come-out diffent, than Steve's pulling out the tranns again, atleast 1/2-way (still screwd)
  17. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    In reply to:
    <hr></blockquote>
    LOL!!! You have helped me on a million things Jeremy dont worry about his worthless comment..he is just BEING an ass. :)
  18. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    ass? i dont get it.
  19. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    and im still kinda curious to find out how to only count 1/4 of the teeth, maybe there's some obvious method that im missing [​IMG]
  20. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx everyone but its kinda a moot point now.....Pure Insanity is down for the count. [​IMG] I had to limp it home 30 plus miles from work. Made for quite a ride. It wont idle in gear and is generally running like shiznit. Anything under 2 grand it bucks and kicks, get above 2 and its like you were rear ended by a train. (WHEEEEE!!!) LOL! I am done playing w/ this carb. I am gonna order a new one and be done w/ it.
    As for the flexplate issue....I am 95% sure its cracked. Its a new flywheel w/ less than 1000 miles on it. I will just pull the motor, get an SFI approved flywheel, and put in a stall converter while Im there. The list goes on, as to why I am pulling it for now.
    Thanx everyone.
    GO</a>
