Starter/Flexplate grind update *FIXED*
Discussion in 'The Garage' started by Muddytazz, Oct 28, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Has anyone ever heard of having to shim a 350 starter with thicker than a 1/16" shim?
    FIXED
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    Re: Starter/Flexplate grind update
    no i haven't. in fact i've never has to shim one at all.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got a 1/16" shim in there now and I'm still like .100 away from tolerance of the engagement.
  4. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    HaHa!! I've got 2 washers and both shims on the outside bolt of mine!! Took forever to get the right distance. Thought I had it perfect, and the other day I heard a clanging from down there....All three bolts holding on to the torque converter work themselves out about 5 turns!! /forums/images/graemlins/rotfl.gif
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I've checked the bolts to the torque converter and crank end and all are tight.
  6. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    I have heard of shimming the starter. The main reason is that when you finally grind off the tops of the teeth with the starter you can remove the shims and it should spin the fly wheel again. Maybe just a tempory fix till you can get to replacing the fly wheel.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Both are brand new though.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well the problem is found! The block is broke where the outer bolt is, 1/2" tall piece fell out from the outer edge. Going to try and see if i can get someone to weld it back on and make a brace for the end of the starter to bolt that end up to the block also as a temp fix under i can afford to get a new block. Hopefully this will get me by for awhile.
  9. muddysub
    Jun 23, 2001
    10,451
    489
    oh my god... that just flat out sucks!! /forums/images/graemlins/shocked.gif
  10. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Same thing happened to me. Cost $200 to get it welded up but it's guaranteed for life.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    updated original post
