starter help please
Discussion in 'The Garage' started by schmuck, Jan 22, 2004.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    my starter makes the grinding noise like its not ingageing with the flywheel well its done this since i bought the truck 3years ago but about six months ago i replaced the flywheel and starter and it still does it and i had to shim the starter to keep it from sticking any help to sole this problem would be appreciated /forums/images/graemlins/confused.gif
  2. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    when you replaced the flywheel did you put the washers back that go between the flywheel and torque converter. I forgot when i did a engine change and that caused the flywheel to flex too much towards the transmission and killed the flywheel teeth and starter in short time. i think the gap should be no more than 1/8 inch
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Correct, no more than 1/8" and no less than 1/16" /forums/images/graemlins/thumb.gif
  4. schmuck
    Nov 11, 2002
    523
    i dont remember thanks ill have to check i was swaping trannys at the time so my mind was in a differnt place
