Starter Help, yes I searched!
Discussion in 'The Garage' started by renny, Nov 27, 2004.
  1. renny
    renny Registered Member
    Apr 20, 2004
    30
    Salem, Oregon
    Okay the outer starter bolt hole on my 400small block has busted off. What I'm trying to find is an OE application 3 bolt starter for the small or big block chevy. My block is predrilled and tapped on all three starter moounting holes so an inline or offset starter could mount to it.
    I did find a CSR performance mini hi-torque starter with this mounting configuration for $259 bucks but I am a cheapskate and would prefer to find a cheaper alternative.
    Thanks in advance
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    AFAIK, no oe starter used all three
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    my powermaster XS starter uses all 3, but its like 220.
  4. dyeager535
    26,976
    The 2 bolt hole "patterns" are for the different nose cones between the 168 and 153 tooth ring gears.
    I also know of no application that used all three.
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    There are cheap gear reduction starters on ebay with either config. Got mine for $60 and it still works great.
  6. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    I've seen one that used all 3 bolts,it was used only one or two years around 1970--had a cast iron nose,if I remember right it was on the bigger C series trucks like a C60 or a bus--they are rarer than hens teeth,and chances of finding one will be slim.Your pretty much stuck with the aftermarket gear reduction style starter when the block breaks off the outer bolt,and it cant be welded or heli-coiled.One guy I know swapped his automatic for a 4 speed when that happenned to his truck--the 4 speed starter bolts to the bellhousing,not the block(at least on the older trucks up to 1980 or so,newer might not /forums/images/graemlins/confused.gif)--he was planning on swapping the 4 speed in anyway--this just made it happen sooner than he expected too. /forums/images/graemlins/crazy.gif
  7. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I had that happen and paid a guy 150$ to weld the ear up and re tap it.
    I went through about 17 starters (noexateration)
    and 2 or 3 flywheels beacuse the geometry just wasnt right.
    I eneded up getting a block and tranfering all the parts.
  8. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Yea cast iron can be welded by a competent shop. The spot needs to be heated up with a torch before it is welded and it should hold.
