Starter installation
Discussion in 'The Garage' started by spearchucker, Jan 27, 2004.
  1. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    When installing a starter, how far away from the flywheel is it suppose to be? Any other tips for installation are welcome too. /forums/images/graemlins/waytogo.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can just bolt it on tight and see how it sounds. If it doesnt sound good, you can start adding shims to see if that fixes it. Seems that cheap starters always sound bad though.
  3. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    I didn't get a cheap starter and I'd hate to screw this one up. That's why I'm wondering what's the correct way to install it. I'd do that with a rebuilt one but I figured there's a better way that trial and error. /forums/images/graemlins/confused.gif
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I suppose you could bolt it on and then actuate the selenoid and take a look at the backlash.
    Hitting it a few times untill its spaced out right shouldnt really harm it at all. If its a good starter, you might not need shims at all. I havnt needed them since I started getting them from NAPA even though they include the shims. The Checker ones are garbage along with the rest of the hard parts there.
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I got a lifetime warranty starter from O'Reilly and it didn't need any shims. Everything lined up like its was supposed to. Best part of the deal was it only set me back $40!
    Kris
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You should have gotten a shim kit with the starter. There is a little thin 1/8" rod that comes with the kit that you insert in between the flexplate and shaft that the bendex(I think thats what that gear is called /forums/images/graemlins/doah.gif) slides on. You should be able to touch both the flex plate teeth and the shaft. If it is not shimmed right than the starter will be overly loud and when it is shimmed correctly you will barely be able to hear it if your truck fires up fast.
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    As a general rule you could use a paper clip to get a reference on the distance and start shiming from there .
    It's crude but it will get you close enough so you don't hurt any good pieces until you get it right .
    Good luck , Tom
