starter interchangeability?
Discussion in 'The Garage' started by KGsK5, Jan 28, 2007.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    finally got motvated to get outside in this cold weather and drop my starter so icould have it tested. took it to autozone and it failed. so that means i need a new one.
    i eventually want to get the bosch gear reduction starter that rene has... but untill i have the money will a starter from a 83 6.2 K30 work?
    thanks
  2. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    The only difference (To my knowledge) is depending on the size of the flexplate. GM had 2 different starters one for a small flexplate and one for the large Manual trannys usualy had the large flywheel. But it should work if they are both diesels.
  3. KGsK5
    Aug 26, 2006
    343
    thats what i thought. i also looked them up on autozone.com and they both have the same reclacement part #s... so im pretty sure they should just wanted to double check
