starter problem
Discussion in 'The Garage' started by d coenen, Nov 8, 2005.
  1. d coenen
    d coenen Registered Member
    Jan 21, 2005
    76
    bonesteel s.d.
    when i turn the swich over it tries to start so i turn the switch off and the starter keeps going (turning)till i can run around and un hook the battery . so itry it again and it starts right up, so i shut it off and try it again and it tries to start but starter does the same thing as first time. ay suggestions? thanks
  2. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Your solenoid is sticking (in the out position). You could try to take it off, take it apart, and clean it up good. It may just be packed with that awesome grease/oil/mud/grime combo we all love. It happened to me once. Otherwise, it's new starter time. :eek1:
  3. d coenen
    Jan 21, 2005
    76
    bonesteel s.d.
    thanks i have some other starters laying around how do you bench test a starter?
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    You just hook positive 12v to the big terminal, and ground the case. Then run positive 12v to the little terminal (the one marked "S" I think, if you have two little ones). The big terminal will need bigger wire, that's were it gets its power. The little one does two things, kicks out the gear to meet the flywheel, and makes the connection for the starter to turn. That is the solenoid, and is what is sticking. Be careful though, starters make lots of torque and will want to jump (like turning on your angle grinder, but way worse). Strap it down if you can.
