Starter problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madman, May 28, 2005.
  1. madman
    madman Registered Member
    Oct 30, 2003
    29
    Hey guys. I have a problem with the starter,well not really the starter, the Bolt hole (not sure what you call it ear, tab....)on the block split. It is a 350 and broke off now there is nothing to hold the starter up except the other bolt. Has this happened to you all before. i dont have the piece that broke off. So welding it back on is out. Is there any way to fix it.
  2. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Only way that I can think of is to weld and build it up, then drill and tap a new hole.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Welding a block is not easy. Do you have two starter bolt holes? The are two types of starters that will work, it might be possible to use the other type if you have the hole for it.
  4. madman
    Oct 30, 2003
    29
    Not sure if it has the other hole or not will check in the morning. Thanks for the responses guys.
