Starter Question
Discussion in 'The Garage' started by az ranger, May 12, 2005.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    After Doing My 700 To 465 Swap I Hooked My Starter Up And Fired It Up. It Started Fine But The Starter Makes A Lot Different Sound Now. It Is Alot Quieter And At A Different Pitch.
    Do I Need A Shim?
    Do I Have The Little Wire Hooked To The Wrong Lead?
    Should I Leave It Alone And Be Happy It Starts.
    I Obviusly Have A New Flywheel In Place Of The The Old Flexplate Could This Make It Sound Different
  2. dyeager535
    26,979
    flexplate/flywheel SHOULD be the same, but with wear and tolerances, they are probably slightly different.
    If it starts and doesn't grind or bind, I wouldn't worry about it. :)
  3. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    flywheel...
    Its quieter because the flywheel is much heavier and thicker than an automatic tranny's flexplate--it does not "ring" and it doesn't "flex" while cranking...if it sounds quiet and no clashing or stripping noise,I'd say its perfect--like they say,"If it ain't broke,dont fix it!".. :crazy:
  4. az ranger
    May 9, 2004
    139
    Safford AZ
    thank you that make perfect sense.
