starter questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by greg83k5, Feb 10, 2002.
  1. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    have there been any changes to the smallblock starter through the years?
    are all smallblock flywheels 168 tooth? this is what my new flywheel is-
    my block is a 77..... in it's previous incarnation, it would occasionally grind, then bust the nose off starters... no amount of shimming would help. now i'm going back with a brand new 168 tooth flywheel we got from a friend. my father thinks there are differences through the years and i do not...
    EXCEPT weren't there some with different sized bolts to match the amount of nosecone body they had to pass through to get to the block?? was that the only difference??
    * keep the greasy side down *
  2. greg83k5
    Nov 2, 2001
    230
    whats up?
    autozone's site is listing different numbers for different smallblock applications.........
    what's the difference, and how do i match this flywheel to a starter?????!!!!!??????!?!!
    i broke like 3 starters before, i DO NOT want to repeat this nightmare!!!
    greg
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    From what I've heard over time I almost want to say there was a 173 tooth ring gear. Go surf www.paceparts.com and call the 800 number...GUARANTEE they will give you the skinny!!!
    9/11/01..Never forget...Never forgive
