Starter Replacement any pix?
Discussion in 'The Garage' started by CHEVY 4WD, Oct 8, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    My question is how do you replace the starter on a SB?(chevrolet)
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Starter Replacement
    Take of the inspection plate and unbolt the starter. Not that hard.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Alright so bacially its one of those unbolt the old stick bolt up the new btw is there any wires or anythig?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    there are usually wires yes, 1 is from the battery, and the other is from the ignition. There is also 2 mounting bolts in the starter that mount the starter to the block.
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    where can you get a new one for a good price?
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Go to your local parts store. If they don't have a starter for a chevy 350, find a new parts store and never return to that one, it sucks. You'll probably be offered the choice between a new and a remanufactured starter. Go with the remanufactured. Depending on brand/where you buy it, expect to pay maybe $85 (including a $10-15 core charge - bring your old broken one back in, they'll give you the core charge back) Total out of pocket, maybe $70 bucks give or take a few.
    Replacement: disconnect battery, unbolt the wires that connect to the starter, take out the two mounting bolts that hold the starter on (be careful, starter will be free to fall now), pull starter back out of bellhousing, check mounting surface and starter for any shims (LEAVE THEM THERE if there are any), bolt in new starter, hook up cables to proper terminals, connect battery, and finally get to START truck!
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    any autoparts store, they are all about the same price (+/- 10 dollars either way)
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    autozone said they have one for $35
    mabe they messed up on the computer or somthen
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    sounds about right to me, that is usually with a core return, you take them your old starter and get a new one.
  10. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Re: Starter Replacement and where to get them for the best price
    Something to keep in mind... If you have a Advanced Auto around...they sell them with a lifetime guarantee. Just wash the mud off the housing when you have to replace. I go thru about 4 starters a year in the mud, and they have never given me any grief. I pulled out my receipt to check, and it only cost $58.00. Just a thought. Other part stores in your area might have the same thing...Good luck. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  11. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    make sure you disconnect the negative battery cable before you start, otherwise you'll prob get lots of welding done down there /forums/images/graemlins/smile.gif
  12. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    replacing a starter is very easy. like others have said its just bolt in type thing. i had to do it at the beach on the first day of spring break. broke down and couldn't start it after that. lol. it sucked. had another starter that a friend gave me. it sucked there there were alot of hot chicks lookin at me. i was all did u have to break down on me here and now damnit. lol. oh well. it was fun. lol. later.
    jacob
  13. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Its a little pricier, but you also might want to look at the Powermaster XS Volt starter. I recently got one for my rig and I love it. I run headers, so my old factory one would lock up from time-to-time due to heat soak. Sucks when you stop on the trail while people are working through a tough spot and then can't start back up again.
    In addition, the factory starter weighs about 18 pounds; the XS Volt unit weighs about 8. It is all aluminum and guaranteed against heat-soak. The XS Volt is also about 40% smaller which makes it much easier to deal with. It uses 4:1 gear reduction, so it spins the motor with ease. All the wiring connections are also on the bottom, which makes things much easier to work with. The factory connections are on the top, which is not always an easy place to get to.
    You can get one from Summit or 4WPW for around $140. Costs more, but well worth the money.
  14. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I would stay away from the autozone starters if I were you. Just spend the extra money for a good one and get it over with. I have so much practice replacing starters it's not even funny.
    /forums/images/graemlins/truck.gif
  15. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I got a new starter from Pep Boys, and with stock exhuast it will try to lockup from heat. I have a Tilton that I will be putting on when I install my headers. /forums/images/graemlins/k5.gif
  16. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Does anyone have a pic of a stock starter IN there truck that i can see Cant get this freaken think lined up im hoping they game me the right 1
  17. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    id goto car quest and get a factory delco starter, since that is what it came with and delco stuff useually is better then most. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  18. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    ANYONE WITH A PICTURE?
  19. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I still wouldent mind a picture but I think they gave me a big block starter.
  20. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    BB is the same. I have one that came off my bro's 305 on my 454.
