Starter selonoid
Discussion in 'The Garage' started by CK5, Sep 20, 2004.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Is there a starter selonoid we can use on a GM starter that doesn't have the ignition post on it (Ford maybe), I have a remote selonoid and don't need it anyway, plus I just striped the positive post so will have to drop the starter, driveshaft etc. to get it out anyway.
    Basicly, is there something I can use that doesn't require the use of the factory selonoid?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive only seen that on a ford. /forums/images/graemlins/dunno.gif id like to get rid of mine also
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    you might try to tear it open and bypass it,(since you already have the remote)
    mabey a basterdising of a ford starter and a chevy bolt block the thing the starter bolts go threw.
    mabey /forums/images/graemlins/dunno.gif
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I need to replace my stock selonoid, its clicking and not starting occationally /forums/images/graemlins/angryfire.gif
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    All of the Ford style starters are just too different to work, I think.
    On a stock style Chevy solenoid, the upper large connecting post gives power to the actual kicking out of the starter gear. If you run power to just the lower conecting post, the starter motor will spin, but not kick out.
    I run a remote Ford solenoid on my truck and I just put a jumper between the "s" terminal and the upper post. As I understand it, the idea of the remote solenoid is not to replace a stock one, but to instead make using it more efficient somehow.
    So i guess since you run a remote solenoid, you could run 2 different cables to the stock starter to make sure it was getting the most amperage, one on the top and one on the bottom post. You would still have to jump that "s" terminal though, but you will be hitting starter with most amperage possible I guess.
    Blake
  6. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    It has more to do with voltage. When you have the factory wires run to the starter and the engine runs and heats everything up the resistance increases. The fusable(sp?) links are down there also. When the engine is hot, the wire to engange the starter sometimes will only have 8 or 9 volts. When using the remote solenoid you will always get the full battery voltage to the starter motor and the "engager". It would be of no benefit to run two seperate wires to the starter if using a remote solenoid. When I did mine I used a small piece of flat steel as a jumper between the two terminals so I wouldn't have to worry about a wire connection coming loose.
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    The reason I ask is because I have a rather large lug on the end of the battery cable and it doesn't quite fit on the main battery post because of the smaller posts, I have to take it off now anyway so maybe I can make it fit with the assembly off where I can see what I'm doing. /forums/images/graemlins/dunno.gif
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    The solenoid on the Chevy starter is responsible not only for making the electrical connection, but also for pushing out the gear. If you bypass it, you can get the starter to spin, but it won't engage the flywheel.
    You would have to go with a different style starter (like the Ford) that uses the centrifigal force of the starter to push the gear out.
    Otherwise, we would all just bypass them and run remote solenoids only.
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Can you get a Ford mini starter. The type that allows you to rotate the starter with the mounting block on the front? If you can maybe its also possible to swap the mounting block to run the chevy bolt pattern block on a Ford starter. This way you have the best of both worlds. Gotta be a way to do it.
  10. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I saw a seloniod relocation kit in Summit. Not sure though if it's the same as your remote. The description said relocates and has a remote option. Hope it helps.
  11. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I used the Summit kit - works great.
  12. CK5
    May 19, 1999
    21,623
    701
    CO
    Welp, the only way to get it to work with the monster battery cables was to ditch the heat shield on the starter mounted selonoid. I would think that would be OK because I have the remote mounted selonoid so heat will not be an issue there, anybody see an issue with not running the heat shield on the starter mounted selonoid?
  13. ugly_blazer
    Apr 12, 2004
    1,214
    I don't have the heat shield on mine, never any problems /forums/images/graemlins/thumb.gif
