Starter Shiming
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RockyRider13, Jun 30, 2002.
  1. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    Is the absolutly necessary? Did i screw up big time when I put in a new starter and just threw out the shims? What can i use to shim it? Thanks
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Buy some GM starter shims in the HELP section at the auto parts store, or you can buy a kit that will tell you exactly how. to hard to explain here but it's really easy...Good luck... /forums/images/icons/wink.gif
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Their only nesscessary if the starter isn't lined up with the flywheel(ie high-pitched screechin noise when starting) I didn't put any in on the last starter.
  4. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    My starters last longer if I shim when needed. In an extreme case you can even damage your flywheel. You can use a .020" wire guage to check the clearance between the pinion tooth and flywheel. Use shims on both bolts to increase the clearance and shims on only the outboard bolt to decrease the clearance. You can also get close by shimming the outboard bolt if it is noisy while cranking, and shimming both bolts if there is a high pitched whine after the engine fires.
