starter tearing up my flywheel teeth
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burbnthedsrt, Apr 24, 2002.
  1. burbnthedsrt
    burbnthedsrt Registered Member
    Dec 19, 2001
    7
    arizona
    My starter was killing my flywheel teeth. With 1,2, or 3 shims
    it is to far away still. So i pulled the trany and tc and replaced flywheel. After a few good starts back to sos. PLease help if you can.
  2. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Did you install a new starter? If not, and you probably will...there is a difference in starters for an automatic and stick. I had installed one into my Burb which is automatic. The starter came off of a stick shift. When I finally put the correct starter in....all was well in the world.
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Could be a bad selenoid in your starter too, not pushin the gear out far enought to engage the flywheel.
    Marty--
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    First fill out your profile and we will know to some degree what setup you have.
    I recently put on a high torgue mini starter and couldnt' figure out why I was chewing teeth also. I had the aluminum flywheel cover off, for other reasons. Once that was back in place, no more nashing teeth.
  5. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> O.k. , that weird ........ As we speak, my Blazer just whines real loud when I try to start it .........It never turns over ........ I don't have on a flywheel cover either .......Why would that make a difference ?
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Riz, you have the classic symptom of a sticking solenoid. Replace the solenoid and your starter should work fine.
  7. Rob 85K5
    1,487
    Pensacola, Florida
    It must correct the angle between the block and the tranny is all that I can figure. The starter I had was sticking, not all the time. When I put the cover and braces on it stopped and has yet to do it again.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I'll do that ...thanks !
