Starter Wire Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jmpd, Aug 18, 2000.
  1. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    I was replacing some wires in my engine compartment(while the motor is out). I need to know what wires go on the starter. I have 2 large ones for the main post and 1 for the small post. I used to have 4 wires 2 large, 2 small, but the wire connector melted and I can't figure out where it went. Some of the wiring has been cut and modified due to the Tpi motor swap a few years back(1990). I looked at a wiring diagram, and I don't thing I needed the 4th wire.
    Thanks in advance(I hate wiring)
    Michael
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    On mine ( it's a diesel ) I have the battery cable , two big wires ( for the big terminal ) and one small wire for the solenoid . I don't know what year you have but on earlier years they had a 4th small wire for the other side of solenoid . This went to the points so it would create a hotter spark during start up . I bet Eagle will have a wiring diagram if you need it .
  3. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    Thanks, I didn't think I needed the 4the small wire because of the 88 TPI motor
    Thanks again
