Starter woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Aug 2, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    OK i feel sorta bad about making this an urgent post cause its not more important thatn anyone elses but today i started up the truck and it sounded like the starter was maing a popping sound. It had done this last night too. Both of these times it had to cracnk for awhile before the engine caught. (that usually happens after the car sits for awhile) But this morning it started up and I puled it out and I started washing some mud off of it. I got done with one side (passenger and went to turn it on so i could move it and get to the other side but when i turned the key it wouldnt turn over. The fasten seatbelt light ccame on and it buzzed at me but that was it. I had just replaced this starter after blazer fest. What do you think?
    Also just before i started wasing it i turned it on the off a few times to try and figure out what that popping sound was. Any ideas? /forums/images/icons/confused.gif
    update:
    thanks guys, i think the solenoid is bad cause after it didnt work the first time i rapped on it with a hammer and then i posted this then i went out oand beat on it again and it fired right up.
    why is it that i go thru starters so fast /forums/images/icons/confused.gif /forums/images/icons/smirk.gif
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Re: *URGENT* Car just died and i need to get to work
    Disconnect the positive batt cable and then check all the connections at the starter itself. If they are all tight reconnect the battery cable. It may be a bad starter, bad solenoid, or even a weak battery...when it did crank over was it slow at all?
    Rene
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Check the fuseable links at the starter too... /forums/images/icons/wink.gif
    -Dan
