Starter Woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schwinnd, Nov 25, 2002.
  1. schwinnd
    schwinnd 1/2 ton status
    Feb 26, 2001
    109
    SE Washington
    Hey All,
    I've had my blazer for about two years and I'm about to go install my fourth starter. I check the clearance and install the appropriate shims but I only get about 9 months out of the starter before it dies. I know this isn't rocket science, it's 3 wires and 3 bolts. Does anyone have any suggestions for me?
    btw it's a '76 blazer 350/350/np203 all pretty much stock.
    Thanks in advance,
    Dave
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Does your starter get exposed to lots of heat on a regular basis? Overheating the starter is one of the best ways to shorten it's lifespan. Are you running headers? Do you have a heatshield?
  3. schwinnd
    Feb 26, 2001
    109
    SE Washington
    No headers, stock exhaust manifolds and no heat shield. I thought it may be a good idea to the shield.
    thanks
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Put in an AC Delco starter and a heat shield. If you do a search for starters, you should find a lot of posts about it.
  5. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    do you do alot of mud running? water and mud dont mix to well with a starter. a combo of gook and heat is probabley your answer.
  6. Can Can
    15,552
    136
    Pam brings up a good point- where are you buying your starters from? Have you been using parts store cheapies? /forums/images/graemlins/eek.gif
  7. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i went through 3 starters on my big block...
    Found out the proper shimming was to only shim one side....
    Go to the dealer and get a good starter or get a napa one...
    /forums/images/graemlins/wink.gif
  8. Can Can
    15,552
    136
    I always read about people going through starters and it makes me feel lucky- my 84 still has the factory starter. Come to think of it, so does my 83 1/2 ton.......
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You know I had 2 blazers and 2 vans, all with 350 chevy and only one always gave me trouble, I broke 3 noses and stalled 2 pinions, and now I am looking for an all cast starter to see if this one will make it.
  10. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    hey, my starters have always had trouble turning my engine over and eventually die. so i finally spent $240 on a powermaster XS Volt Starter. it has 4.44:1 gear reduction. its a really nice starter and can always crank my truck over now.
    NITRO
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    My problem was never the power.
    I align it right and it starts perfect for a week then it starts grinding, so I loosen it and retighten it, and it works great, and so on and eventually I find a bad pinion and a broken nose.
    I am guessing if I had the rear brace this wouldn't happen.
  12. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    have you replaced your flywheel?? sounds to me like the tolerances are off. o yea, are the teeth on the starter or flexplate shiny in between them. it could also not have enough shims in there to create the gap needed
    NITRO
  13. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I ran into a very similar problem about 1 to 2 months back (search my name). Went through 3 flexplates and like 6 starters. Built my own tail end of the starter support bracket. Finally found out just by luck of trying, got another starter from a different place, put it on, and worked perfectly. Got to measuring the old starter and come to find out, the store that I got them from originally got a bunch in to sell that were all machined at the wrong angle /forums/images/graemlins/shocked.gif were it mounts to the block.
  14. reddog64
    Nov 9, 2000
    3,325
    You need to SHIM HALF THE STARTER....
    either the outside bolt or the inside bolt... more than likely the outside bolt needs a shim or 2 or 3 under it to rotate teh gears into more contact with the flywheel...
    What i have to do....
    Get a lifetiem warranty witht he starter you buy... only buy once :d
    I did this and havent had probs since....
    PM if lost... /forums/images/graemlins/thumb.gif
  15. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Do you have real starter bolts in it. The ones with the knurling on them.If not the starter will shift around. I was eating starters and switched to one from a 69 chevelle big block with manual trans. It's an all cast nose, at does't flex like alum. You might try a starter for a 96 and up pickup. They are smaller and farther away from the heat. I'm not positive , but I think they will only work on 86 and up engines with the one piece rear seal /forums/images/graemlins/truck.gif. I'm sure someone will correct me if I'm wrong.
  16. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I went through numerous starters from Pep boys and Autozone. Tried shims up the wazoo, checked clearance, even went as far as replacing the flex plate. What finally fixed it was buying an AC Delco starter, using starter bolts, using the support arm on the back. Its been over 2 years now and not a single problem since.
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    To all who responded to me:
    I will tell you everything that happened to me, and you will notice that everything you mentionned has been tried or was not the case.
    It was running fien untill one day it started slipping, bad pinion so I rebuilt it with a new pinion.
    It was fine for 2 days then it started to grind.
    I tried to shim it, and I found out that the only way to get it to align was shimming only the outside bolt.
    It worked for a couple of days then it started to grind again, so I took off the shim and tightened it and it worked perfect.
    ...for a couple of days then again, so I shimed it again, and it worked, after 2 day it grinds so I take it off and check it the nose is cracked.
    I get a starter that was on my other blazer, running fine.
    It ran for a week then same problem.
    I checked the bolts to see if the knurling if in the wrong place ( I have seen different lengths) it was fine and it fit snugg which it is suposed to do.
    I checked the flywheel teeth, they were a little shiny so I changed it and put a new one.
    Worked for a week then the same.
    The only difference between this blazer and the other, and all my other GM trucks is that the rear brace/braket, you know the one on the tail of the starter, was missing.
    So my guess is that since the nose is Aluminum, and the braket is missing, the vibration is making the bolt enlarge the hole and shifting, when I loosen it and realign it and tighten the bolts it works until the vibration shifts it again.
    That is why I decided to put a cast iron nose, and it worked.
    At the time I didn't think this small bracket would make the difference, but now I know. Every little bit helps.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    I will get the braket just for extra insurance but the cast iron starter helped.
    By the way, just for the info:
    All chevy V8 starters might work, since they all have the same mounting bolt pattern, but I came upon so many sizes (diameter) and after some research, I found that there are 3 sizes:
    one for I6, V6, and 305 and smaller V8's.
    one for the 350, and 400 V8.
    And one for big blocks.
    Now I only get the big block version, much stronger, and indestructible. /forums/images/graemlins/thumb.gif
  18. schwinnd
    Feb 26, 2001
    109
    SE Washington
    Wow! Thanks guys. It sounds like I need to double check my tolerances when I go to put this on (after Thanksgiving). I have only used napa's starters and it does have the rear brace. What I noticed was my motor mount on that side appears to be broken. I'm wondering if that may be part of the problem?? Of course it's all bolted to block anyway. Man do I love this stuff.
