starter
Discussion in 'The Garage' started by aknight_sa, Aug 28, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi all,
    when i try to start the engine (either hot or cold) there is always a big metal banging sound.. after the engine starts.. its normal...
    could the problem be from one of the starters parts or from the flywheel...
    thanks
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Banging or grinding? Get under there and have someone else start it and see where its commin from. If its commin from the starter area then pop the dust cover off and see whats goin on.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    you may need to shim it away from yer flywheel, if its too close itll make a funny grinding/squealin noise. plus youll tear up starters and eventually the flywheel...:doah:
  4. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    i hope there is no problem with the flywheel, as i dont want to go through the hassle of removing the transmission to replace it...
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    ya its a major P.I.T.A. did it once. hopefully never again\.
  6. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    if you do need to replace the flywheel, try to get a cherry picker and pull the tranny tunnel hump off from inside your vehicle, then you can drop a line down to support the tranny w/ the cherry picker. it will make the job a TON easier.
