Starter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jan 2, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My starter got messed up the other day, but i messed with the connections on it, and got it to work for a few days. This morning in a parking lot, the same thing happened, no turning over, etc. My fingers were numb, so I took the trailer hitch off the reciever and smacked the starter a few times with it, and it worked for about two starts. Now I have a hammer with me, and use it every other time I start it. What could be wrong with it? Do i just need a new starter? How much are they, and how hard to put on? Thanks
    90K5
  2. dyeager535
    26,977
    New starter. Pretty easy to replace. Two bolts to the block (do NOT overtighten them when putting back on, you will break the block) and two for the starter wires. Might as well get one with solenoid. I have never really had much problems with aftermarket starters, however, I do not run headers which tend to run close to the starter and burn them up quicker, besides making the starter harder to remove (in some cases) You can get them from GM also. I think the last aftermarket starter I bought (rebuilt GM unit which probably 99% are) from a chain store, with life warranty and a solenoid, was $50 or $60. Worth changing every two years for the price if you ask me. IF they fail that often, which hasn't been my experience with the aftermarket units.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Sounds like you got a bad spot in the brushes, take the other posts advice and get a new one.
    K5:Big, slow, and flys through the snow. [​IMG]
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    If you were able to get it to start the first time by messing with the connections you might want to stop beating on it. I'd go back and find out what's wrong with the connections. Just might save the cost of a starter--if it's not too late. Just a thought from the peanut gallery.
    Smitty
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Probably the starter solenoid. Just replace the starter. I got my last one for about 30 bucks at Advance Auto. As long as you turn your old one in for the core charge they are cheap. Good luck.
    When all else fails... Check the blinker fluid.
    78 K-5
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    But...what if I like beating on it?!?! j/k
    90K5
  7. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i remember i had an oldsmobile a long time ago. for about the last 2 years i had it, banging on the starter was a frequent pastime. then suddenly the problem went away and i sold it.
    Knife.
    knife.coloradok5.com
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I just finished replacing it. Starts like a charm now, except it makes a wierd noise right before it catches. Does this have anything to do with those shims i keep hearing about?
    90K5
    <P ID="edit"><FONT SIZE=-1>Edited by 90K5 on 01/03/01 12:55 PM (server time).</FONT></P>
  9. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    What kind of noise? Are there any shims on the starter now?
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The noise is not really wierd, just higher than before. i asked a mechanic today and he said its nothing to worry about, i probably just a have a high torque starter.
    90K5
  11. dyeager535
    26,977
    Shouldn't makje any weird noises, however if its not teeth grinding, gues I wouldn't worry too much, especially if its lifetime warranty. Were there shims when you pulled it? If so, those are supposed to be re-used when you replace the starter.
    One question I have, is why re-use the shims? Yes, the block is a constant. The nose of the starter, when replaced, is not. To me, if anything, when replacing a starter, the original nose cone should be swapped to the new starter to prevent a problem. I have no clue how GM measured for a shim, seems odd to me with manufacturing tolerances being what they are between the block and the starter nose cones, that it would be pretty near impossible. On top of that, with the way the starter operates, where would you take a measurement, since the angle of the gear on the starter is what hurts the ring gear, not necessarily the nose cone to block itself.....
    Dorian
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Dorian, you need to take the measurement between the flywheel ring gear and the starter gear. You have to manually extend the starter gear to take the measurement. The shims that were installed at the factory may or may not work with a different starter due to manufacturing tolerances on both the block and the starter. The correct procedure is documented in most good service manuals. Many times, you can get away without going through all the steps and just bolting the starter on. But I've had starters that hit the ring gear instead of turning over the engine until I installed some shims and measured things. [​IMG]
  13. dyeager535
    26,977
    Ok thanks Harry, wasn't sure if GM actually went to the trouble to measure all of them like that, or if they had some other way (like fire it up and see if it grinds hehe)
    Dorian
  14. Chris1972
    Chris1972 Registered Member
    Nov 21, 2000
    22
    Just got a new from AC Delco its works good and wasnt to expencive. Good luck.
    Another thing when you turned the ignition switch did the lights go out????
    Chris
    www.broadpark.no/~csteinsv/
  15. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How much did the AC Delco one cost? i went to the dealer and it was like $290
    90K5
