Starters
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 10, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    OK, I've modified and replaced almost every part on my truck, but I still have the cheapo rebuilt starter from Parts America. I'd kind of like to upgrade that part too. Anyone else done this? Are those gear reduction starters the way to go? TIA
    '73 K5
    Chevy good...Ford bad
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Get one of those "Mean Green" starters. I think that's the name. It has the word "green" in the name. They're awsome!
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The gear reductions not really neccesary unless you've got insanely high compression. I've got a NAPA heavy duty and like it just fine.
  4. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Unless you are cooking OEM type starters(because of compression) I dont see why you would really need a stronger (more expensive) starter. But if you need one the Mean Green's are the way to go
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  5. i wouldn't wanna drag an expensive starter thru water and mud...... the one for the boat was sealed, and of course a helluva lot more expensive than the usual pep-boys replacement, i wonder if that would work? i DO know that starter shields are awesome for removing heat, and divorcing the solenoid would be even better!
    greg
