Starting Issues HELP
Discussion in 'The Garage' started by bigblazer433, Mar 13, 2005.
  1. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    Its a 87 Jimmy witha 350TBI, and when the engine is cold and I try to start it it cranks for a good 8-9 seconds and when it starts it stays running. But when the motor is warm the same thing happens only when it finally starts it will die immediatly after. I have to repeat this starting process atleast 3 times before it stays running.
  2. dyeager535
    26,980
    Do you hear your fuel pump prime when the key is turned to "run"?
  3. bigblazer433
    Jul 29, 2002
    38
    El Reno Oklahoma
    ya the fuel pump primes
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    not to high jack but mine wont start and I dont hear the fuel pump prime where is the sensor located that does that?
  5. dyeager535
    26,980
    I don't know how to do it specifically, I just know there is a test lead on the fuel pump relay that is supposed to tell you if the relay is working or not. Believe that can also be done through the ALDL connector.
    I'm sure someone will chime in either on this post, or try starting a new one with a descriptive subject line.
