STARTING PROBLEMS??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gabdam, Apr 24, 2001.
  1. gabdam
    gabdam Registered Member
    Jan 25, 2001
    26
    NEW YORK
    HI EVERYONE, MY PROBLEM IS WHEN I START UP THE TRUCK FOR THE FIRST TIME , IT STARTS UP OKAY BUT IF I DRIVE IT FOR A WHILE THEN SHUT IT OFF WHEN I GO TO RESTART IT, IT SOUND AS IF THE BATTERY IS WEAK AND IT DOESN'T WANT TO KICK OVER AND I GET A JAMMING SOUND FROM THE STARTER.. SHOULD I BE LOOKING FOR A NEW STARTER CAUSE THE BATTERY IS NEW..
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Could be overheating associated with the solenoid. Do you have headers? Does it work if you let the engine cool down? If so may want to relocate the solenoid. If running stock manifolds, could still be the solenoid aging causing this. Also, turn the caps lock button on you keyboard off, it's like yelling.
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I second Wheels opinion. If you run headers, you might try a heat shield for the starter if you don't want to relocate the solinoid.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey, all you need is a bigger hammer and you can fix ANYTHING... lol[​IMG]
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  5. gabdam
    Jan 25, 2001
    26
    NEW YORK
    sorry about the cap lock, i have stock manifolds..if it cools down there's no problem starts right up.
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I had a dually ('82 model) and when it got hot, the starter wouldn't turn at all. Like the battery was completly dead. After 3 starters I learned that there were some years in the '80's that had a problem with the ignition wireing. Well, I put a starter button on and never had a problem since. I don't know it that's your problem, but you might be able to rig up a temp starter button and see if that fixes it.
  7. gabdam
    Jan 25, 2001
    26
    NEW YORK
    thats exactly what happens it seems the battery does'nt have the juice to crank it over when its hot , but when its cool its a hard start but it will start....what i mean by hard start is that it doesn't kick over at first turn of the key, it will crank two or three times then start.
  8. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    On the dually, it was just dead, I mean just nothing....barely a click. If it sorta turns over, that might be different, but I'd put a starter button on it just to see. I wouldn't mount it anywhere until you know that it fixed it, but I'd try it.
  9. gabdam
    Jan 25, 2001
    26
    NEW YORK
    i'll give it a shot ..i have to buy a new starter..i'll try it if it works thank you in advance
  10. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I hope it's that simple! Good luck!
  11. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I'd suggest getting Summits GM remote start kit which comes with everything you need including a special brass terminal that fits on the starter.
    Summits remote solonoid (just a Ford solonoid) is on the left, ignore my battery isolator on the right.
    This will fix GM's famous hot start problem.
    Shawn
    87 K5
    few mods[​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    wow clean motor compartment shawn mine is never that clean lol nice wiring too
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
