starting problems
Discussion in 'The Garage' started by lak2004, Jan 31, 2007.
  1. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    i have been having some problems starting my blazer and tonight it wouldnt turn over at all. it smells like it burns oil pretty bad. it cranks and its not the battery but it just wont turn over. i am sure it gets flooded but there is no helping it. i need to check the plugs, but what could it be if it is burning lots of oil?
  2. dyeager535
    26,982
    191
    So the engine turns over (cranks), it just doesn't start.
    Burning oil is rings or valve seals, you need to see if you've got spark and fuel if it won't start.
  3. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    What usually happens is it with try to start once and then die and then after that it just will not start until like the next day. Last night it wouldnt start and this morning I went out and it fired right up.
  4. dyeager535
    26,982
    191
    Again, check spark and fuel.
    It might be flooding so bad it won't restart until it evaporates, but something like the ignition module is quite a bit more likely in this case.
  5. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    Ok I will check it out today if I get time, thanks for the input.
