starting probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris12, Oct 24, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    Well it seems when i drive my truck into town which is 10 minutes away. I will shut it off and start it right away again but it will not start right away. IF i leave the truck for like 10- 20 minutes and try to start it again it starts right up. What si the problem here. It just started doing this when i swtch my battery from a red top optima to a normal motorcraft battery.
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Exhaust is overheating your starter relay wire in another starter relay else where under your hood. Also try a search I am pretty sure there is a thread on this already.
  3. chris12
    Apr 23, 2006
    267
    May i also ad that it started doing this on sunday when is switch from a red top optima to a motor craft battery. Optima battery wasn't mine.
  4. chris12
    Apr 23, 2006
    267
    Well i have to drive it to school 2 more days and its in the garage for a new clutch. But we had this problem in my dad J**P and you let it cool down and it started right back up. it ended out being the brushes in the starter.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It's usally the starter solenoid is locking from heat. Typically happens on older starters, or cheap ones. Your optima probably had enough juice to overpower it to kick in. I'd replace your starter, or at least the solenoid.
    THey also make little heat shields that attempt to keep heat away from the starter in an attempt to prevent this from happening. A good quality starter is preferable though.
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
