Starting the 1/2 to 3/4 ton swap tomorrow.
Discussion in 'The Garage' started by jk3078, Feb 3, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    So we are finally going to swap A.R.'s 70' 1/2 ton over to 3/4 ton with discs. We're using a 1 ton rear for the proper spring pad width. From what I've read on hear this should be a bolt in, anything I missed? What about swapping over the power brakes? We have a 76' donor truck so parts should be no problem. Just thought I'd get yalls .02 before digging in. Thanks.
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    You may have to swap brake proportioning valves if his still had front drum brakes instead of discs. Also, you may have to relocate one rear shock mount- maybe both- but you might be able to get away with reusing one of the existing rear shock mount locations.
