Starting to piss me off ***PROBLEM SOLVED WITH GOOD SOLUTION***
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Muddytazz, Jan 16, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: Starting to piss me off
    Is the motor stock? I had similar problems with starters years ago on a motor with high compression and big HP
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    motor is stock 350, stock exhaust, stock everything except the lift kit.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What keeps breaking? Is it the teeth/drive gear? Do you have the starter with the proper teeth to match your flexplate? Sorry if that's a dumb/obvious question and you've heard it numerous times, but it could save you some frustration if that's the only problem. /forums/images/graemlins/confused.gif
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    starter gear/ring gear are correct, this is the first one that has actually broke the nose cone. I think that is due to the fact that i have to shim the damn starters a 1/2" on just the outside bolt in order to get the drive gear and ring gear to mesh
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    It really sounds like there is a parts combination problem. Having to shim the starter 1/2" seems way wrong. /forums/images/graemlins/confused.gif
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I am going to say this and I hope you don't think I am being a smart alec. Is the ring gear mounted on backwards??????? I have been there and done that, I had the same problem.....
    John
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    No offense taken, I double checked it when i installed it, and i also looked at it today and its mounted on right....
    I found out a little tid bit of information from the old timer parts
    guy at napa that is a retired GM engineer. GM casts there engine
    blocks at multiple plants and that there is a 1/2" varience in the
    mounting surface of the starter, that is the whole reason for having
    to shim it. The starters are all machined at the same spec.
  9. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I don't know if this will help but.. I have seen a *few* starters that had a "shim" cast in to the around the bolt holes on the nose cone. the side that is closest to the flywheel is thinker than the other end. the first few I saw were on 400's but in the last couple of months while helping a buddy change a couple out and they were on 350's
    just thought I would throw that out there
  10. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    from the peanut gallery
    BEEN there done that after 3 starter's in 30 - 45 days here is what my problem was
    Ya know that 1 longer bolt that comes out the back of the starter well its supposed to have a brace that goes to the engine block welll if the brace isnt there you will break the starter or ring gear when you hit the bumps- dips hard from the motor flexing and the starter not flexing fastenough with it or visa versa i had this 1 dip in the road that got mine all 3 times till i put up that brace as i like to hit it about 50 - 60 in my crew cab as it rides so smoooth
    well hope it helps
    im out
    P.S. thanks for putting up this ?? i think i am gonna go hit that dip again tomorrow just for fun at about 70 /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/crewcab.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Starting to piss me off ***PROBLEM SOLVED***
    Problem solved everyone. When I found out about the engine blocks being cast at various sizes, I did a little measuring against my dads 77 burb w/350 and my sisters 80 K5 w/350 and between the 3 engines, there was a 3/8 of an inch difference from the same spot on the top of the block down to the mounting pad of the starter. So, since machining a completely assembled block was out of the question, I found a cast iron nose cone off a dead AC Delco original starter and had to machine the pad down .090. Now the starter works perfectly with no shimming what-so-ever, and a paperclip is just slightly tight in the gap. If anyone else has had similar problems, try checking into what I've had to do. Thanks for all the ideas though.
