Starting with my lift tomarrow.
Discussion in 'The Garage' started by Pvt. Maggot, Feb 6, 2007.
  1. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    Well since skyjacker decided my rear spring bushings were rare, costing me 15 extra dollars, I can start putting my lift on, a few questions, should I leave the swaybar on or remove it? anything I should do while installing? just wondering, thanks alot.
    Jack
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    get rid of the swaybar bro.take pics while installing.:D
  3. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    Will I see any negative effects from this?
  4. 83 oneton
    83 oneton Registered Member
    Feb 11, 2006
    77
    clackamas oR
    most lift springs are stiffer then stock so shouldnt have anytrouble with body roll. when removing the swaybar depending on springs it will flex more
  5. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    they are skyjacker 4" springs. :) so all the swaybar on the k5 basically does is keep from body roll? hm.
  6. 83 oneton
    Feb 11, 2006
    77
    clackamas oR
    yes it just helps with body roll
  7. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    I was thinking that it kept the steering in line, kept it from getting all out of wack, learn something all the time. hah thanks for that.
