Starts but doesnt Run
Discussion in '1982-Present GM Diesel' started by BARRAZA, Oct 4, 2002.
  1. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    Got my M1008 to start but it will only run for a couple seconds at a time. Seems to respond to the throttle, ie it revs higher when the petal is pushed but still only runs for a bit. Have replaced the filter, checked the fuel solenoid, and checked the fuel return lines for blockage. The line from the filter to the injector pump is new, and the pump seems to be pumping fuel up to the filter ok. It runs longer on the first try after 30 minutes of being off, but still only for maybe 6 - 8 seconds. Also, it is starting almost instantly, barely having to crank it at all. Anyone run into a problem like this or have any suggestions?
  2. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Could be bad fuel, seeing that they only need fuel,air and compression to run.
  3. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    I've only had that experience when I've had air trapped in the fuels system. By no means is this the only cause, but it is worth looking into. One good method I have heard is to get some clear tubing the same size as your return lines between the injectors and place it temporarily in place of the original return lines... have someone start the engine and look for bubbles in the lines. This may not work in your case since the engine doesn't run very long and you run the risk of introducing air into the system which may complicate your problem.
    Jon /forums/images/graemlins/burb.gif
  4. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    I am leaning toward air getting into the fuel line. I would start by working my way from the injector pump back and look for a fuel leak. When I had that problem it was coming from one of the fuel filter fittings.
    The other thing it could be is the fuel pump not having enough pressure. I would think it should be around 8 - 10 PSI.
  5. BARRAZA
    Oct 17, 2001
    259
    USA
    Update - I have been going over everything because I thought it was an air leak of some kind. Turns out we are all wrong, I took the injection pump to the shop for an overhaul and the guy knew exactly what it was, governor in the pump is coming apart and pieces were stuck in the vent checkvalve blocking it. After it runs for 8-10 seconds, pressure builds up and it shuts off, then it would start again and immediately shut down. After a prolonged shutdown, enough pressure would bleed off to let it do the same thing again. Same effect as a blocked fuel return line.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well at least you found out. /forums/images/graemlins/smile.gif
    Now we have one more thing to check if we ever get the same symptoms, thanks for the update.
