Starts with screwdriver but not with key
Discussion in 'The Garage' started by Mudstud, Apr 13, 2007.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    76 K5 with a 350. I washed the truck went to move it a coupl eday later and nothing happened when I hit the key. The gauges jump and twitch like normal and the headlights seem bright so I clean both sides of the + battery cable and the other wire connection on the starter and still nothing when I hit the key. No clicking, nothing. So I turned the key to ON and hoped under the truck with a screwdriver and arched the starter. It fired right up.
    I didn't have time to peel back the cable insulation and inspect for corrosion and I seriously doubt it is coroded so what other things might be the problem? The electronic deal inside the HEI? The switch itself? A fuse? What do you think? The electonic thing in the dist was replaced back in 1999 sometime.
    Thanks, Dan
    I know there is a way to check the electronic deal in the HEI with a meter but not sure how to.
  2. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    fusable link or corroded starter wire (the one that activates the solinoid) Thats what is sound like to me. My 84 K5 had the same problem a few months ago, the wire that activates the starter solinoid was corroded into but the insulation was still good it was hard to find. I just started pulling on the insulation until it broke. Then I did the aux solinoid upgrade and I love it, no more starting problems
  3. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    So you are saying check the lil wire on the selinoid? I will do that. Tell me more about this aux selinoid upgrade. Whats that about? Parts needed? Any pics?
  4. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    how about the neutral saftey switch on the column? i had a truck that wouldnt start in park, but would in neutral, or if you jiggled the column
    try neutral or tapping the switch, its on top of the column towards the firewall.....
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I had a column that would do that. you had to hold up on the shifter lever.
  6. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Here is a preety good example. I used the most heavy duty solinoid I could find at the local parts store. Its preety simple a it cures the chevy hot start problem. There is a lot of info on it just do a search! Just thought you wont be able to see the pic (so pay you $25) Just do the search youl find plenty
  7. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    OK thanks, I have never had a hot start problem in this rig. I will check all things suggested here hopefully Sunday. Any other suggestions please chime in.
  8. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Well I only got to try the nuetral start- didn't work. Tried holding the shifter up, jiggling it in Park and Nuetral and nothing. I'll hav to check the wire on the selinoid. And where exatly is this fusable link someone mentioned. What color and location?
    Thanks, Dan
