Startup?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wallyb, Feb 26, 2001.
  1. Wallyb
    Wallyb Registered Member
    Jan 15, 2001
    24
    Southwest Minnesota
    I thought with fuel injected motors the motor should fire right up, right away. Or does it take a few seconds?? My blazer cranks for a few seconds before firing. I just put in new plugs and fuel filter also! Just wondering on how yours trucks are starting??
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    My 87 TBI Jimmy takes a couple turns when cold, I always turn the key to run, let the fuel pump pump until it stops, crank and it will fire after a couple seconds. But when it is hot, I let the fuel pump pump like I did before but it fires right off, dosen't even turn over once. Hope this helps.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    The TBI's really don't fire up too quick in terms of being FI'ed. It is only about 13psi fuel pressure so not a ton more then a carb. If it takes more then about 3 seconds to crank over when cold you could have a leaky injector or fp regulator... it would usually be combined w/ a small blk puff of smoke, but it would fire right up after that till you let it sit for a while.
    1987 Chevy K5 Blazer- 350 TBI
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    im not sure if this is good or bad, but in my carburated 85 i tap the gas a TINY bit nad it works awesome
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Thats exactly what you're supposed to do. Actually the manual say's 2/3 of the way down but if we went by the maunual we'd still be running 235s, I dont think so, lol. Its kinda funny but my '82 with the carb starts faster than my dads '89 Jimmy with FI. I usually hit my pedal two full pumps and I'm good to go. Of course when both are trucks are warm his can run circles around mine, what till i get my 3.73 12-bolt [​IMG]
    Two lanes wide, twelve yards long, sixty-five tons of American pride....Canyanero!
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Actually it wont start till it registers enough oil pressure the electronic carbs also do this.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
