Steel Bellhousing For a Truck Tranny?
Discussion in 'The Garage' started by MaxCrack, Oct 17, 2006.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I am looking for a steel bell housing that actually fits the Chevy truck transmission. Anyone know of a source?
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Ditto that. I'd like to find an SFI approved bellhousing that could be drilled for an NV4500.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'm not aware of one that has either the spigot hole size or the bolt pattern(s) for truck transmissions. That isn't too big a deal though. Any competent machine shop should be able to bore the spigot hole to the correct truck size. Best bet there would be to bring a truck b/h for them to measure.
    Typically the mfg's tag some small tabs on the inside to add thickness where the trans mount bolts thread in.
    The one issue I see is with those trans' that have the lower two bolts that come thru from the clutch side & thread into the trans case. Since scattershields are full circle, access to those bolts might be a bit of a pain.
  4. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I've always wondered if you could machine a SM465 bellhousing to fit a NV4500.
  5. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    You can try Lakewood you would probably have to contact there specialty department
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I called Lakewood about four months ago about this, and I got a reply back that they dont make one. Maybe they could custom fab one, but I bet it would cost some $$$$$
  7. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    May as well just buy one and modify it. Once in a while you can find one used. I'd take on the project if you were closer. It's really not that big of a deal, but you do need some specialized tools (mill w/ boring head).
