steel bellhousings
Discussion in 'The Garage' started by ryan22re, Feb 13, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    will the front driveshaft clear the blow proof bellhousings used in drag cars? talking small block with a 465.
    if i am thinking correctly, the center bore will have to be bored out too right? around the input bearing retainer?
    any other problems associated with running these bellhousings?
  2. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    everybody running around with one foot?
    maybe i didnt ask the right question.
    anybody running a steel bellhousing?
  3. mudnmyvayne
    mudnmyvayne 1/2 ton status
    Jan 13, 2004
    173
    Texas Panhandle
    Id like to be. But thats not much help:o
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    How much is a steel bellhousing? My hydro bellhousing is cracked to ****.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i dont know, but im thinking that the NHRA makes the certs only last a year or two, so they have to be changed that often. or at least thats what i was told. so they may be avail pretty cheap. which is why i ask.
    *edit* new ones seem to be going for $300-400 from summit.
    saw one for 200 on ebay.
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    anyone?
    need to know if its worth pursuing.
  7. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    They have to be inspected.
    They also have bells for the hyd. clutch setup.
    Why wouldn't it clear the shaft?
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    dunno, thats why i was asking.
    would prob convert to hydro with aftermarket stuff or mod factory stuff to fit.
  9. Slapperbar
    Nov 29, 2005
    2,747
    3
    No mods needed they make for both.
  10. Slapperbar
    Nov 29, 2005
    2,747
    3
    I raced a P/ET S-10 out in Hawaii for a few years.
  11. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    What kind of HP are you running to need a blow proof bell housing? I could see the need if you are mud draggin' or rock racing! I would think that any bell housing that would fit without an adapter would clear the shaft. They try to keep the size down so clearance isn't an issue. You might try the Summit racing tech line. They are usually more knowledgeable about the four wheel aspect of parts. Or call the manufacturer of the bell housing you want to run. Weight is probably going to close to double. I hope everything turns out all right for you.
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If you are concerned bout the "grenade factor", just buy a ballistic blanket for the bellhousing.
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Guys, it has nothing to do with the blowproof:rolleyes:... hes asking cause his stock aluminum one is cracked. this is just a route to take so he doesnt have to replace it with something else that may verywell fail
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Also i cant think of any clearance issues, but like you said the hole would have to be enlarged.
  15. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I emailed Lakewood to see if they made a bellhousing for 465's and they replied back saying that they dont. Does anyone know of a steel bellhousing that could be modified to work with a 465 and still be hydro???
  16. 79k20350
    Nov 22, 2004
    7,757
    Ct
    all you have to do to make a 465 work is take it to a machine shop and have them enlarge the center hole. its 4.xxx on a regular bellhousing and they need to enlarge it to 5.xxx, i dont remember the exact dimensions...
  17. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    It will be needed to be bored out to 5.125"
    Tom
  18. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I thought that there were some trucks that had steel bellhousings from the factory?
  19. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    As far as I know they were cast iron housings not steel .
    Tom
  20. koldsimer
    Jan 10, 2005
    1,480
    texas
    Yup, those were the ones I was thinking of. My bad.
